How many runs, and fuses.
You can double up, but you honestly wouldn't be pulling as much current as 2 runs of CCA would allow you to pull. I would personally double up on all grounds at least though.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
So one run of power, should I run a ground too, or just ground to body
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
Ground to body will be just fine.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
i would still consider an extra run of 0g, you are really maxing out that wire and just isn't something I personally would be comfortable with. Especially once you get an upgraded alt.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
idk what brand of cca ur going with but that aq amp wants 200 amp worth of fusing and the rockford wants and then your looking at another 60-80 for the rockford. so over all 280 ish max amp draw. so im with other guy here with a 2nd run. or a single run of ofc again depends on brand and what not
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
  • Who's Online   1 Member, 0 Anonymous, 1822 Guests (See full list)
