775Tundra Posted December 30, 2013 Report Share Posted December 30, 2013 what is shank size? The stem of the bit. You can get 1/4 inch diameter bits with a 1/2 inch shank. so i have to get 1/4 diameter bits only? No. But the jasper jig is calibrated for a 1/4 bit. I just do the math to compensate for a larger bit. 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold Link to comment Share on other sites More sharing options...
Borris The Blade Posted December 30, 2013 Report Share Posted December 30, 2013 You can get 1/2 bits to. I'd use a 1/4" dia with the jasper since set up for it. Not sure if they make a 1/4" dia with a 1/2" shank though. Another good bit to get is a flush trim bit, they are great to have. It's like rubbing your wiener up against a sheep. Link to comment Share on other sites More sharing options...
SlamminBeats Posted December 30, 2013 Author Report Share Posted December 30, 2013 ok so to recap. i need to get 1/4 shank bits that are either 3/4 or 1 inch long? and i can cut through 1/2-3/4mdf? what about for roundovers? Link to comment Share on other sites More sharing options...
Borris The Blade Posted December 30, 2013 Report Share Posted December 30, 2013 That all depends on how much you want to round over. A 3/4" will round off 3/4 and a 1/2 will cut a 1/2 and so on. There are so many possibilities with a router you will wonder how you lived without one. It's like rubbing your wiener up against a sheep. Link to comment Share on other sites More sharing options...
tacomaguy1 Posted December 30, 2013 Report Share Posted December 30, 2013 Sounds like you never used a router before....be cool with it at first. They can be dangerous You can cut through as thick of a piece of wood that you want, well as deep as the plunge will go. Like others mentioned don't cut tthe whole thing at once. Do it in multiple passes Team Flex Issues Link to comment Share on other sites More sharing options...
Borris The Blade Posted December 30, 2013 Report Share Posted December 30, 2013 Lots of good vids on the uses of a router for car audio https://www.youtube.com/user/CarAudioFabrication/search?query=router It's like rubbing your wiener up against a sheep. Link to comment Share on other sites More sharing options...
pa-pa-platypus Posted December 30, 2013 Report Share Posted December 30, 2013 just wait till you hit your first screw with it lol This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4 Link to comment Share on other sites More sharing options...
SlamminBeats Posted December 30, 2013 Author Report Share Posted December 30, 2013 yea ive never used one. my first use is to make speaker rings and stuff. so i need a bit for that, Link to comment Share on other sites More sharing options...
SlamminBeats Posted December 30, 2013 Author Report Share Posted December 30, 2013 1/4" diameter. I use a 1" long bit because I don't like to cut through all of it at once. I find it best to make a few passes to keep the heat down on the bit and I burned up one trying to power through 3/4" MDF.link to bit? my router says 1/4 and 1/2 collet? is that bit diameter? is shank size what you match up to the collet size? so i can use 1/2 and 1/4 shank?Correct. Up cut http://www.lowes.com/pd_200101-353-85911M_4294696058__?productId=3748001&Ns=p_product_qty_sales_dollar|1&pl=1¤tURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&facetInfo= I use this one, does the job and is good for making flush mounts. http://www.lowes.com/pd_65729-353-85613MC_4294696058__?productId=1095801&Ns=p_product_qty_sales_dollar|1&pl=1¤tURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&facetInfo= I bought that second bit you linked. I can make 6.5 rings with it right? Link to comment Share on other sites More sharing options...
