Ported or sealed??
Skax
I was planning to get a new box I have 2 4ohm p3 15's running on a bdcp1500 and plan on upgrading to a 2500bdcp when I get the money but just wanted to know what type of box would be recommended ?
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
you will smoke those woofers on a 2500. unless you plan on getting some 1000 or 1200w woofers.
they peak 1200 wats each is that fine?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Ported /end
what u mean by end ?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
dont go by peak for daily, thats what the rms rating is for.
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
give them a constant 1200w and they will go up in smoke. They're rated at 600. If you do get the 2500 wire them to 4ohms.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
t2500 on those, as mentioned above, is going to blow the things to pieces. Better grab some T2 15's if your trying to run a fosgate sub on a 2500.
Oh yeah, ported.
  • Who's Online   0 Members, 0 Anonymous, 5110 Guests (See full list)
