CodyLucente Posted January 13, 2014 Report Posted January 13, 2014 looks like your putting 200rms on 2 subs if your just looking for 500rms @ 1ohm you dont gotta spend a shit load of money also if you dont know how to set gains DO NOT try an do it your self iv learned the hard way i agree completely i have learnt the hard way as well on subs more expensive than those RF at least my amp is ok Subs= SoundQubed HDC3.112 Amps= Audio Technix1200.1, Sony XM4x40 & Clarion XC1410 Rear= Pioneer 6"x9" coaxial Front= Polk 6 1/4 componants Trunk Lid= Pioneer 6 1/4 coaxil Battery= Optima Yellow-top (front) Shrunken 35AH Wire= 0/2 AWG welding Cable! Alternator= 125amps Extra= Continuous duty solenoid
Rockford96 Posted January 13, 2014 Report Posted January 13, 2014 don't rule out "good" used equipment. that can save you some $$ and get a W-A-Y better amp / subs/ etc!!!! I bought my dd amp used still working great! My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
jarrius Posted January 14, 2014 Report Posted January 14, 2014 The q-1200 should use 4awg and if you have 2 dual 4ohm subs you can only wire to 4 and 1 ohm. I would get the 1200 and just wire your subs up to 4ohms. That would be much closer to the rms of your subs and be way less of a strain on your electrical. Edit: also i would not get the hifonics suggested. Cost less yes but no ware near as good of a amp as the sq 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
john253a Posted January 14, 2014 Report Posted January 14, 2014 ^as above That's why I susgested it Don't wire to 1 ohm and turn gain down Do it right Wire to 4 ohm and gain match it propley Then Latter when the funds are better you'll be able to upgrade the subs and run 1 ohm final giving to 1200rms to the subs
Jordan Stanley Posted January 15, 2014 Author Report Posted January 15, 2014 http://www.sonicelectronix.com/item_34763_Rockford-Fosgate-R750-1D.html I think I might go with this seems to be a perfect fit no? anyone want to point out the pros/cons to this amp? thanks for the help/opinions its much appreciated
jarrius Posted January 15, 2014 Report Posted January 15, 2014 http://www.sonicelectronix.com/item_34763_Rockford-Fosgate-R750-1D.html I think I might go with this seems to be a perfect fit no? anyone want to point out the pros/cons to this amp? thanks for the help/opinions its much appreciated I run the 1200w version of this amp and i have to day i do very much enjoy it. But the 750 is 210 for $60 more you can get the soundqubed 1200 and have more power when you decide to upgrade subs already there. Also with going with the bigger amp its current draw will be less at 4ohms. 1 major con of this amp is how the terminals are pointed down at 45 degree angle. 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Kyblack76 Posted January 15, 2014 Report Posted January 15, 2014 2 dc 10ks strapped at .25 SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Jordan Stanley Posted January 16, 2014 Author Report Posted January 16, 2014 2 dc 10ks strapped at .25 huh?
Jordan Stanley Posted January 16, 2014 Author Report Posted January 16, 2014 http://www.sonicelectronix.com/item_34763_Rockford-Fosgate-R750-1D.html I think I might go with this seems to be a perfect fit no? anyone want to point out the pros/cons to this amp? thanks for the help/opinions its much appreciated I run the 1200w version of this amp and i have to day i do very much enjoy it. But the 750 is 210 for $60 more you can get the soundqubed 1200 and have more power when you decide to upgrade subs already there. Also with going with the bigger amp its current draw will be less at 4ohms. 1 major con of this amp is how the terminals are pointed down at 45 degree angle. alright yea that seems to be the general consensus Im back to getting the soundqubed 1200 thanks
