Skax Posted January 14, 2014 Report Posted January 14, 2014 so recently i was heading to see my mom and it was me and my girl and she looked in the backseat and was like why is there smoke back there and i was like wtf r u talking about and i smelled it and then i turned and was like oooh shit and saw this ever since then the music sounds high pitchy and the subs dont seem like they hit right lol . i have some 0awg already in my room i was ganna replace this with when i found time guess the time is now? or any ideas? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Tarball Posted January 14, 2014 Report Posted January 14, 2014 fuse it or lose it. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Tarball Posted January 14, 2014 Report Posted January 14, 2014 seriously though, put some properly soldered or crimped terminations when you replace the wire - and fuses. Consider a CAP a power source. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Skax Posted January 14, 2014 Author Report Posted January 14, 2014 seriously though, put some properly soldered or crimped terminations when you replace the wire - and fuses. Consider a CAP a power source. yea i got a fuse under the hood if thats what ur talking about lol what it was is the connection was really loose and so i guess it just fucked the wire completely? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Herokight Posted January 14, 2014 Report Posted January 14, 2014 Put a fuse on every connection to and from the capacitor. Check the manual for your amps for the proper fuse rating to use. Edit- Every POSITIVE connection. Grounds don't need a fuse. Lane AKA HeroKight '96 Jeep Cherokee Classic 4x4 R.I.P. Molliboo $200 for new tires, on a jeep!? Is she stealing them or building them with a heat gun and rubber bands? You hear that????That's a category 5 shit storm coming n8: hey you doing today. What's it like being a bitch? you can pm me if you'd like to explain why you arent one. Just like you did for your vs threads. ^^^Rules. Follow them.^^^
Tarball Posted January 14, 2014 Report Posted January 14, 2014 lose connections generate heat - heat melts wire insulation, no insulation causes bare wire to ground out, any power source will rapidly drain and cause more heat resulting in a fire, loss of propery and maybe even injury/loss of life. Fuse 12"-18" from any power source. Capacitors aren't normally fused because they dont have a large reserve but looking at what you are dealing with for termination I would fuse everything and terminate every wire - properly. Check out some videos and info hear on the site lots of good info here. HOT solder or hydraulic crimp any ring terminals. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Skax Posted January 14, 2014 Author Report Posted January 14, 2014 Put a fuse on every connection to and from the capacitor. Check the manual for your amps for the proper fuse rating to use. Edit- Every POSITIVE connection. Grounds don't need a fuse. will do just gotta figure out what size for which amp also should i go ahead and replace wire? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Tarball Posted January 14, 2014 Report Posted January 14, 2014 fuse less than the wires amperage limiit for the wire length. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Skax Posted January 14, 2014 Author Report Posted January 14, 2014 lose connections generate heat - heat melts wire insulation, no insulation causes bare wire to ground out, any power source will rapidly drain and cause more heat resulting in a fire, loss of propery and maybe even injury/loss of life. Fuse 12"-18" from any power source. Capacitors aren't normally fused because they dont have a large reserve but looking at what you are dealing with for termination I would fuse everything and terminate every wire - properly. Check out some videos and info hear on the site lots of good info here. HOT solder or hydraulic crimp any ring terminals. problem is idk if my run is even 12 inches from the cap i run my 4awg from cap to 1500bdcp and i think a 8 or something to my 440.4 tma for mids 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Skax Posted January 14, 2014 Author Report Posted January 14, 2014 fuse less than the wires amperage limiit for the wire length. any idea what size fuses i should run then ;o? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
