Finally got my pillar in with Autometer gauges. 2 volt and a clock all matching the OEM flow just how I like it.
What do you guys think?
Rolex you sicken me.
Just let me finish my pie
~ Juice
had to build a step down for the media player in dash
As stated a 7805 was all I needed. here's the down and dirty in pics.
Made for less than $5 and built my way. 9-20 volts in with a constant 5 volts out!
WP_20141006_23_04_17_Pro__highres_zpsac5
BTW, the 1st pic was parts I cannibalized from an old VCR. I ended up buying new parts but the VCR parts would have been fine.
This will do 2 amps max with the heat sink
~ Juice
I have no other clock in the car and i had it laying around. Matched the interior pretty good so it got used.
One volt under hood at battery one is going to be at the input to the T2500 bdcp
~ Juice
the step down transformer was built to power this little guy
so it can interface with all this
and watch media from either SD or USB thumb drive
~ Juice
  • 2 months later...
Got around to running my power wire. Got fed up and didn't want to go under the car so I had to figure it out. There's tons of write ups out there on how to fit a little wire through the grommet located behind the computer but nothing showing this!
Fist 1 moved the computer completely outta the way
exposing the grommet:
from the inside:
disconnect some plugs and pull teh grommet all the way out:
remove the grommet and cut out the center:
now you can see what you can really fit in it!
Bundled up nice and neat! 2 0 gauge runs, factory wiring and my power wires for gauges.
from the inside:
power running:
power off:
the gauges are controlled by a relay throwing a negative trigger when the car is on or in the acc position. as you can see I wanted to keep with the classy OEM look under the hood so I used so cheap ass split loom. I'm all about stealth! lol
~ Juice
