Ford Explorer keeps dying with new Stereo.
Its one of my buddies Ford explorer's. I showed him how to install stereo decks while I was installing his new one. I went off of the wire chart for connecting the wire harness together. Now he is experiencing the car dying on him, he does not have subs yet, I just installed the stereo deck.
Why is his car dying? I made sure everything was hooked up correctly. I've done stereo decks before and had never had a problem like this. Whats wrong? Solutions? What should I check when I go and help him try and fix it?
I would say pull it back out andake sure its not wired in to a constant 12v wire. Thats really the only thing i can see is that something is always on
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Is it hardwired. Meaning did you cut the factory harness
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
for some reason my mitchell account isnt working right now, but a quick google search came up with this
http://www.explorerforum.com/forums/attachment.php?s=3fcc1c7218657ec75b61478973b4bba6&attachmentid=43223&d=1193894799
i would check the grey/black wire to make sure it isnt broken, or shorting out, seems like the only wire that could shut the vehicle down as it runs to the PCM.
This page is crispy_chick3n approved.
© crispy_chick3n inc
Nooooo, you should never cut factory harness.
you can do what you want, if you know how to do it.
car keeps dying yet you "made sure" you wired everything correctly.......
does the HU stay on with the car off?
He never had this issue before the stereo. Im sure it isnt the gray/black wire. I do remember hooking up the 12V battery wore, not ignition. I think I did both. I cant remember, Should I try switching the 12V battery wire to the 12V ignition? Ignition makes hell lot more sense. I think the deck came with two 12V+ cables. So if I have the ignition and the Battery hooked up at same time should I just cut the 12V battery wire on the deck and block it off? You only need one 12V, right?
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
