*SOLVED* *Im happy as balls*CANNOT get wire into my doors...last straw before i'm done....any help? *pictures top of page 4* and first post.
Coat hanger is sharp and will cut the wires if you try to force it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I'm willing to bet if you point your finger down there is a space right? That's where you need to go.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I used either 8 or 4awg wire instead of a coat hanger. It's not sharp, isn't hard to maneuver, and finds it way through the second hole.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Ever try an angled drill? I drilled new holes using one in my old car. It puts your drill bit at about a 45* angle. I'd suggest a small bit then a step up bit to get to where you need it. Just be very careful! Sorry if that's been posted
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
In the last pic, I had to probe the part that "seals" to the door with a tiny Philips head screwdriver.
I know.. It may not be recommended, but it worked for me. DO IT SLOWLY AND TAKE YOUR TIME!
LMFAO so true
:blush:
how would 4 gauge wire fit through a hole that im havgin trouble fitting 12 gauge?
Buck up bart! Buck up!
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
so n8, if i stick my finger throught the boot from the jam i should go down, so if im under the dash i need to go up then right?
My best option may be go under dash with a longggggg drill bit and make a hole and pray it comes out the boot in the jam. I can avoid the wires pretty easily its a matter if if the hole will ome out into the jam.
I didn't know whether u were having a hard time fitting the wire through, or guiding the wire through.
I didn't read the 4 pages :/
LMFAO so true
:blush:
You will want to angle to the bottom of the car towards the floor if you are going in near the grommet. If I remember right. There should be a spot near the bottom that will open up and allow you to get wire through.
So from the top go down. You want to get through the grommet first if you don't you can forget about it basically. Because you won't have the leverage to force it through.the grommet.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
