Need Help Planning System for Friend
Sup guys,
First off, I apologize if this is in the wrong forum section. I couldn't decide where it fit best, but I knew it wasn't SQ or Ground pounders ;)
so here's the deal: My friend is going to be getting his car soon. He does have a job, so I don't have to scamper around looking for crap equipment, but I'm still on an ultra tight budget. Basically I'm looking for equipment that is from good companies but that won't break the bank. Here's what I'm thinking so far:
Sub: 1 12" C2 Audio Threatcon 2 (the one with minor cosmetic flaws is 110 dollars)
Head Unit: Pioneer DEH-150MP (65 bucks)
wire: Knu 4 gauge wiring kit (27 dollars) and 6 ft of knu 8 gauge (3 dollars) with a knu 1x4-2x8 distribution block (10 dollars)
The part I've been having trouble with are door speakers and an amp. Since the budget is so limited, we are focusing on the front-stage only. His brother has a cadence 5 channel amp laying around that we will use to power whatever door speakers (hence the distribution block) but I think it'd be best to use a seperate amp for the sub itself.
As far as speakers I've seen, RE makes some decent looking cheap components / coaxials, and Cadence makes some that look ok too. What else looks good? I don't want to spend more than 70 for a pair.
As far as amps, I've looked at a couple. The alpine mrp m500 does 500rms into 2 ohms. You can get it for about 125 on amazon. The other one that I like is the Sony XM-ZZr3301. I would usually avoid sony at all costs, but this one is Cea certified so it should do the 600rms into 2 ohms that it is rated for. It's 100 bucks on sonicelectronix.
So what do you guys think? What would be some other good options? I don't want to spend more than 125 for the amp, and I'd like it to be in that 500-700 watt range.
Thanks alot!
Subs = 2x Rockford Fosgate p110's in custom ported box
Amp = Rockford Fosgate 451s (115 watts rms x 2 into 4 ohms)
Rear = Sony xplod 6.5 coaxials (they were on clearance at target :D )
Front = Soundstorm 6.5's
Wire = some 8 gauge crap my friend gave me
head unit = an older alpine
I'M POOR OK :(
Jbl gto501 ez for the amp, if you bump you speaker budget up a little bit you could get some nendo cz 6.5s or incriminator 6.5s
Used to have a loud truck
mm, looks like all of that is out of the price range. :'( What do you think about the NVX coaxials?
I'M POOR OK :(
The jbl is only $100 on Amazon
Oh, so it is. The reviews hint that it isn't as powerful as the rating lets on though. :'( What do you like about it?
I'M POOR OK :(
  • Who's Online   0 Members, 0 Anonymous, 1661 Guests (See full list)
