sorry noob question but please reply
So I'm ordering the xs D3400 and see if that would fix the problem the buy so 0/1 gauge to do big3 and I'm going to wait for tax refund to get H/O alt
For the big three, I'd recommend some Sky High Car Audio cable if you want to make it yourself, or you can by a kit from them.
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
when you do the big 3 get a good solid ground for you alt case. a alt mounting bolt is a good idea but if not possible as close to where to alt mounts as possible.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
while the car is running the alt case is the ground for the entire car. you can do an engine ground and be fine im just saying the closer to the alt the better. if you alt is mounted to the head then the only thing connecting it to the block is the head studs so in this case I would ground the head imo. the better the ground for the alt the better your electrical should be.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
whats your voltage at idle I know mine at idle before the big 3 it drop to 9.5v and the amp will have a fade sound but while driving it will be at 10v but know with the big 3 it only goes 11v at idle
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
you want a frame gound, the shorter the better. if you want you can ground to the battery but I would still do a frame ground to.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 3289 Guests (See full list)
