High Amp Alternator
Hi guys just recently installed a high amp alternator in mustang. On a long drive today the alternator almost caught on fire it was that good damn hot. Needless to say I need a new alternator and serpentine belt -_-
However any ideas of the causes, Alternator manufacturer failure? or could it be caused by the fact I didnt get around to up grading the alternator to Battery +ve wire.
Any ideas would be much appreciated.
Cheers,
Brad
BF XR6T with Focal Audio
it depends what system your running so how much power are you running
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
The new alternator wasn't from fleabay, was rated for 200 amps.
Was un aware of grounds needed to be made bigger. Was just relying on the alt chasis to engine. but this sort of makes sense as the roush mustangs have there alternator mounted on top with a different to the standard GT. So roush use the GT alternator but remove 2 of the 4 mounting lugs. This may be alright to do with the standard alt but I'm guessing the hi amp couldn't cope with two mountains lugs being removed?
So do I need to run a wire from one of the bolts that holds the chasis of the alternator together to the battery -ve?
We recommend to do at least a 1/0 AWG from the alternator to the battery for high amp applications. A mounting bolt would be sufficient for a ground. IMO I would use the same size cable - & + form the alternator directly to the battery.
big 3 is REQUIRED when installing a high output alt.
who's the alt from?
Okay so would those wires and lack of be the cause for the alt burning out? Will a gates belt be fine?
  • Who's Online   0 Members, 0 Anonymous, 3129 Guests (See full list)
