What would be more beneficial to me ?
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I'd add a second pos and double up the neg to where you have it now. You might not need it but It definitely couldn't hurt. I agree you don't need to run a neg from the front though.
Okay, so I have a mechman "260" amp alt, 850 cca agm batt up front, big 3 done, and 2 92 ah cell tower back up batterys in back. Would it be more beneficial for me to add a 2nd run of positive from alt to rear batts, or do a run of negative from the negative of front batt to rear batt negative ? Oh sub amp is dc 2k and I only drop to like 12.5-12.6 at idle wangin away at full tilt on a dc lvl5 18.
I certainly would not run a second run off the alternator. The stud IS NOT a good distribution point to run to the back of the vehicle. That will cause the regulator to overheat and become LESS efficient. I would run a larger cable to the front battery and then distribute from there. The ground is totally up to you if you want or feel the need to run it. otherwise I would make certain it is clean and tight
So I have a question then, that applies to this thread, right now I have 2 runs of 1/0 OFC coming off my alt to my under hood battery. Yes it goes to the under hood battery but it is two runs. Would it be better to make it a single run of SCHA 2/0 OFC instead? Would it not matter at all? I have multiple batteries under hood and in the back and plan on running some big power (have 7 amps in my spare room that need to go in). Thoughts?
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
IMO if the alt can't produce more power then a single 0 gauge wire can handle then the 2nd run is kinda pointless.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
IMO if the alt can't produce more power then a single 0 gauge write can handle then the 2nd run is kinda pointless.
I hear ya. BUT most people over do their electrical anyways. Also, it's the Mechman 370 Elite 6 phase (252 at idle) so I wanted to make sure I didn't restrict it in any way. From alt to batt. is cheap short run, all good. Thanks all
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
http://www.stevemeadedesigns.com/board/topic/151155-the-big-3-upgrade-whats-the-real-benefit/#entry2157321
from the best on car electrical another thread to read up on. Big 3 explained in the best way possible
op, thanks for these questions. Some of the info in the threads a linked I forgot. good refresher for me.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
from the best on cast electrical another thread to read up on. Big 3 explained in the best way possible
I know I've been through there before but I really need to go through it again as I've apparently forgotten what I read, lol. Thanks for posting this up, fits well in this thread for all to read, especially the OP. =)
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
actually meant for op actually lol.
Everyone can use a refresher from time to time though.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 2370 Guests (See full list)
