How to wire speakers at a lower ohmage
girlcrazy_4
I am running focal components X4 in my truck, and I purchased a focal amp to run them. It only puts out 75watts RMS at 4 ohms or 140watts rms at 2 ohms... The amp is unable to keep up to my listening needs so I need to bring my speakers to 2 ohms. How can I go about doing this?? Am I able to put a resistor inline somewhere??
FPP4100 Technical Specifications
4-channel car amplifier
75 watts RMS CEA-2006 x 4 at 4 ohms
140 watts RMS x 4 at 2 ohms
240 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
you have 4 speakers and 4 channels. best you can do is run one speaker to each channel, or only run the front two speakers and bridge the amp to each speaker.
Resistors arent going to help you. Cant fake an ohm load like that. Wiring in series will reduce your wattage, dont try to bridge the amp and run two speakers in parellel off each channel cause the amp wont do 2ohms when bridged.
Or go buy a bigger amp.
What is the rms of your speakers anyway?
Most focals ive seen are around 75 rms, they are made for SQ not Loud. You do know the SQ is usually not loud right?
In 2 days he will be asking for help because his amp is going into protect or over heating.....
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
strangeduck is right on this one.
one thing to add to it though, "ohmage" is not a word.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 1180 Guests (See full list)
