RiottStarr Posted February 5, 2014 Report Posted February 5, 2014 Where is the best location to get CLEAN power for yor head unit? I have heard of and was thinking of running it from my amps? Thoughts?
P4killer_ Posted February 5, 2014 Report Posted February 5, 2014 Clean power? The factory 12v constant should be plenty clean. Even if you power directly from the battery.. it wouldnt make a difference.. Dirty power I think you mean the head unit making noise.. thats a grounding issue or rca issue etc.. There isnt a dirty 12v it should be rather stable without an issue. Its not like the 12v source is ac which is converted to dc for the h.u... not counting the alt. Maybe I mis understood something here.. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
RiottStarr Posted February 5, 2014 Author Report Posted February 5, 2014 I believe I heard the SM in SMD say in a video that that is the cleanest/Best pace to get your power? I may have heard wrong.
Kyblack76 Posted February 5, 2014 Report Posted February 5, 2014 i dont get what your asking? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Wicks Posted February 6, 2014 Report Posted February 6, 2014 I would tap off of a spare location from your stock fuse panel. Same location your vehicles CPU and other electronics feed from. Also make sure you have a solid ground. This voltage should be near your stock battery/alternator and will tend to be stable. The power input to your amps could have the tendency of dropping which you probly don't want running to your HU. The HU most likely has a wide voltage input range but I'd keep it as stable as possible. If you truly want a stable and clean voltage supply to your HU then you could purchase a 12v DC-DC converter (voltage regulator). It would take your variable vehicle voltage and regulate it to a solid 12v. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
