BamaBoy334 Posted February 10, 2014 Report Posted February 10, 2014 Wass up bassheads. I need some help. Im deployed and have about 3 weeks left in this hole.. I have a SQ Q1-3500D.1 and 2 HDC3 18s (copper coils) waiting on me to return and I want to wall them in my 07 Dodge Charger. Im trying to figure out power to ^ft net ratio and port area for this build. What im working with: 46.5" wide, 35" high, and may be able to get anywhere from 19"-23" deep The subs will be wired @1ohm. I wanna tune between 34-37hz. I wanna be able to reach lows and still have a wide range on music (25-60hz if possible) I've been researching on builds like this and im aware that the suspension is stiff af and this really isnt a sub for lows, so ive been seeing, but know its achievable. I wanna build it so when it does hit those low hz, you can tell 4sure, and maybe pull off some hair tricks. (i def wanna do that haha) but still have a so so range on music. mostly rap. maybe some Dance Gavin Dance from time to time (thats my shit) anyways.. it will be daily so the port will be centered/vertically or ran across the top/horizontally (would def like some input on that as well) im open to all suggestions on how i can optimize this build to get the most out of these subs with everything i have available if you need to know anything else, then just ask. ive been using bassbox and torres to come up with designs but i really want to hear from someone that knows what they are talking about when it comes to Soundqubed. I just want a complete Soundqubed set-up in the whip.
Soccerballzs Posted February 10, 2014 Report Posted February 10, 2014 Thanks for your Service! What kind of car you putting system in? http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
BamaBoy334 Posted February 10, 2014 Author Report Posted February 10, 2014 hahaha his interests are lows and vagina Don't forget soundqubed Qmat for the rattles! is that qmat legit?
BamaBoy334 Posted February 10, 2014 Author Report Posted February 10, 2014 Thanks for your Service! What kind of car you putting system in? no problem.. 07 dodge charger
Desousa93 Posted February 10, 2014 Report Posted February 10, 2014 hahaha his interests are lows and vagina Don't forget soundqubed Qmat for the rattles! is that qmat legit? i was wondering how the qmat was too. def tuned in for a walled charger New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
BamaBoy334 Posted February 10, 2014 Author Report Posted February 10, 2014 hahaha his interests are lows and vagina Don't forget soundqubed Qmat for the rattles! is that qmat legit? i was wondering how the qmat was too. def tuned in for a walled charger well depending on how much free time they give us when i get back, itll be soon. if not, i dont take leave until april so thats when it will get done if i dont have any other chances. def gonna have a build log
Desousa93 Posted February 10, 2014 Report Posted February 10, 2014 if not qmat i found some deadener enough to do the whole car and then some. lol http://store.secondskinaudio.com/b-stock-40-pounder/ New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
funky Posted February 10, 2014 Report Posted February 10, 2014 I doubt you are going to get 25-60 response. If you build it right you might get 28-58 I cut mine off at 58 60 and above is more mid bass. You can get down to 25 with aq/sq but what I have found is they play down to 25 but the lose a lot after 28. I have 4 hdc3 18's and hit 150.5 at 28hz but I lose 4db going to 24hz. I peak from 36-44 all above 156.5. What I did was ran 6 cubes a piece with 16-16.5 sq in per cube port tuned to 35hz. They sound great but lows are not the same as other subs with loose suspension, but I think they are much cleaner sounding through the frequencies. Hope that helps. Learn to live life, not just be alive! The QX build log-http://www.stevemeadedesigns.com/board/topic/178358-06-infinity-qx56-rebuild/ Carbon build-http://www.stevemeadedesigns.com/board/topic/187645-civic-wall-build-4-dc-xlm2-15s-it-is-playing-videos-on-friday-pics-updated/ Chode Box-http://www.stevemeadedesigns.com/board/topic/182547-chodes-triple-kerf-box-build-box-done-and-playing-videos-up/ Kenny's Build-http://www.stevemeadedesigns.com/board/topic/169916-k3n12ocks-05-xb-tiny-rockford-fosgate-amps-sotm-may-2014-pg-8/ Dan's Slant Box-http://www.stevemeadedesigns.com/board/topic/185711-slant-box-i-built/ You Tube-http://www.youtube.com/channel/UCGXvMZHvEhYMmyjgxpPGiJA Never do anything you would not want to explain to the paramedics!
BamaBoy334 Posted February 10, 2014 Author Report Posted February 10, 2014 I doubt you are going to get 25-60 response. If you build it right you might get 28-58 I cut mine off at 58 60 and above is more mid bass. You can get down to 25 with aq/sq but what I have found is they play down to 25 but the lose a lot after 28. I have 4 hdc3 18's and hit 150.5 at 28hz but I lose 4db going to 24hz. I peak from 36-44 all above 156.5. What I did was ran 6 cubes a piece with 16-16.5 sq in per cube port tuned to 35hz. They sound great but lows are not the same as other subs with loose suspension, but I think they are much cleaner sounding through the frequencies. Hope that helps. this helped alot. i could care less really if it fell off at 55hz really. i just want to get low but still have an acceptable range on music. 35hz sounds really good and i can work with that port area. gonna use torres real quick then sketch it up. thanks for the input
