ok, i got some question because ive never met, or built any 'super systems' i.e. meade's tahoe
im thinking of building a custom box in my trunk for 4 15's
do i need to build the box so that each of the subs is closed off to each other as in one box, and its sectioned off inside, or can they all be in just one open air box, and also
what happens if i dont build the box big enough so that it is not the recomended size (smaller) does that effect the sound quality, or loudness, id rater it sound better than just loudness
also its a 02 mustang, but after i build that, i plan on removing the back seats and adding 3 or 4 more 15s in a fiberglass enclosure, and i have NOOOOO idea wtf im doing then lol, but any halp on the trunk box will be appreciated =)
huh? did u say something?
you're lucky if you get 2 15's in the trunk of a mustang. if you put a sub in less air space than specified it will decrease the output and quality. hope that helps.
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
ok, well are you talking about box airspace? or are you talking about as in, out of the box airspace?? because i am determined to make it work and be right lol
Your best bet is ONE good 15 ( FI BTL, Rockford T2, etc.) with all the power you can put to it. I have seen the size of those mustangs trunks. You don't have room for crap unless you wall the wall. Good Luck
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
^^^^^^^^^^^^^^^^^^the truth
Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? :blink:
How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face :)
mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs
Id like to see 4 15s in a mustang! lol but i dont think 4 will fit, it would be a tight fit with 2. Id say go with 2 good 12s or one very nice 15 like dc, fi, re etc with plenty of power.
1997 2 Door Blazer
Bagged & Body Dropped
SBC/TH350
Well put.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
x2
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
  • Who's Online   0 Members, 0 Anonymous, 991 Guests (See full list)
