Running two alts. Need advice.
Well its not even installed yet. But if my h.o. unit puts out 136a that ain't gonna cut it..
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
in your situation I would dial the external to match the V setpoint on your stocker until you can afford to get a second H.O. alt.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
IMO guys one High output alternator is better than NO high output alternator. If you are going to go through the trouble to fab one in the give it a whirl throw a couple batteries in see what shes got.
The h.o unit is installed atm. And actually ive figured out that it has to be doing more than 136a because the way the wiring diagram is, its like a current divider and the cars current draw isnt being measured at all at the battery.
Anyway. What I really need to know, and maybe mech man could answer this is:
Is it possible to run the externally reg unit and the stock unit at the same time? And if so what would be the best way to measure the stock set point?
Also I assume that eventually running say a mechman alt with my EA alt would be ok? Some ppl use the same external reg.. which most have a max field current of 15a..
I think two alts would max that out. But I know ppl do it.
Or would I be better running separate regulators too?
Thanks
Setup:
Xs D3400/ Xs XP3000
Thanks
im pretty sure somewhere i read they make voltage regualtors for multiple alts..
:domodance: :domodance::morepower1:New Build in the Making :morepower1: :domodance: :domodance:
1999 Infiniti I30 Limited
if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
Thanks
You can run 2 alternators off of the external regulator. IF the factory alternator is internally regulated then it will have to be converted to external.
So running a ext reg unit. And an internal reg unit is a no go I take it?
Setup:
Xs D3400/ Xs XP3000
You can but you would need to set it to the same voltage if you plan to run it in conjunction with the vehicle. Or you could run the externally regulated alternator straight to a battery bank and charge it to the intended voltage for the batteries
Right but is there a way to enure they charge at the same point. Being that the stock would be ecm controlled?
Setup:
Xs D3400/ Xs XP3000
  • Who's Online   0 Members, 0 Anonymous, 1740 Guests (See full list)
