batteries
I have a yellow top that puts out right around 450amps I want to get a second battery I was going to go with a 600 amp second battery but I read thet if Ur second battery is bigger then Ur first it will just draw of the first one so does this mean that I can only go with a 450amp second battery I'm buying a Q2200 two hds300 12's don't worry looking into a alt right now
that's cranking amps, it only effects when you first start your car before your alt takes over.
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
swap the optimas out for good agm batteries. like the ones they sell at sears (the AGM style ones).
if you're going to get an alt, only look at mechman or dc power.
Any AGM batt should be good to -40F.
Optima Batts are OK but not what they used to be since they got sold and moved to Mexico.
But, most an AGM battery can be connected to another AGM Battery.
Yellowtops are AGM. So get any other AGM of any size and you will be fine.
It's really when you mix chemistry that you have an issue.
For example. A wet cell and AGM have different ESRs. So their natural resting voltage will be different.
This different will cause a small amount of current to flow between the batts even when no load is present. This will keep the plates warm and reduce the life of the batts.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
  • Who's Online   0 Members, 0 Anonymous, 3129 Guests (See full list)
