Daniel Shepard Posted July 19, 2012 Report Posted July 19, 2012 After reading through 57 pages I need some input. t line enclosure for type r 12 fs=29hz qms= 7.89 qts= .47 My qms and qts are higher then recomended on the first page, is this a issue? These specs being said here are my calculations center of surround to center of surround= 10" 10/2=5 5x5x3.14= 78.5 fs= 29hz 1130/29=38.965 38.965/4=9.741 So if Im doing this correct my port opening will be 78.5 sqin and my port length will be 9.741ft long? Max dimentions in the car are L=39, H=16 W=16-20". The Type R 12 has a 7.7" mounting depth so Im not sure how to fit the sub in the port size I figured. I would gladly paypal someone more experienced a few bucks to help me design this tline as long as I knew the steps taken to get the final result so I can learn off of it.
STEvil Posted July 19, 2012 Report Posted July 19, 2012 are you sure its 10" at 1/2 surround to 1/2 surround? MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
Daniel Shepard Posted July 19, 2012 Report Posted July 19, 2012 are you sure its 10" at 1/2 surround to 1/2 surround? See that sounded strange to me as well. It has that accordian type surround, and the half rib to the next half rib is 10? We are talking about the rubber surround right? the outer most part of the rubber surround to the other outer most part is 10.75, Thats off alpines website. But we are wanting the center of the surround which is 10".
1 Sock Posted July 19, 2012 Report Posted July 19, 2012 Made new one for 2 10's if anyone is interested:
BassMunky Posted July 19, 2012 Report Posted July 19, 2012 dammmm Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
STEvil Posted July 20, 2012 Report Posted July 20, 2012 are you sure its 10" at 1/2 surround to 1/2 surround? See that sounded strange to me as well. It has that accordian type surround, and the half rib to the next half rib is 10? We are talking about the rubber surround right? the outer most part of the rubber surround to the other outer most part is 10.75, Thats off alpines website. But we are wanting the center of the surround which is 10". I was just finding it odd that it was exactly 10" across from center to center was all. If you're measuring a ribbed surround you want to choose the point between the ribs (assuming the ribs are the same width each) and realistically there is a bit of fudge factor, so its not something to be worried about if you're ".2" out or so. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
Daniel Shepard Posted July 20, 2012 Report Posted July 20, 2012 Am I anywere close to where I need to be? Any imput would be appriciated
STEvil Posted July 20, 2012 Report Posted July 20, 2012 where's your line measurement? Just eyeballing it looks close, too late at night to do math.. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
Daniel Shepard Posted July 20, 2012 Report Posted July 20, 2012 where's your line measurement? Just eyeballing it looks close, too late at night to do math.. I just noticed my math is off, I cant continue a true 8" port at a depth of 22. Ill have to figure out how I screwed up
BassMunky Posted July 21, 2012 Report Posted July 21, 2012 mean Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
