severancej Posted July 23, 2012 Report Posted July 23, 2012 Hey man I read through the t line topic and wanted to build one instead of a ported box. Could you sketch me a design? I listen to slowed rap, bass mekanic, decaf.. Max dims in 98 dodge ram ext cab rear seat removed 50w 21d 40t. There is a little more room in height. I have two sundown E12 on order! their dual 4 ohm I was going to run one ohm final load My amp is a rockford T500-1bdcp 800w@1 ohm Sub specs: Fs 35.8hz Qes0.56 Qms6.79 Qts0.52 Le1.85mH Vas47.6L BL15.4NA Cms0.13MM/N Mms 156.6 grams Sens n/a 1w/1m Xmax 12mm one way Rms 400w Displacement .12ft cubed Please help with some sketch or advice I think this t line would be better and easier to build than a sixth order someone else had suggested to me. Thanks a lot, James 98' dodge ram 140A alt Big 3 XS D2700 JVC kd-r310 Rockford T500-1BDCP 2 Sundown E12 Ported 4cubes 35hz Rockford P400-4 2 Infinity reference 3way 6x9 2 Polk DB 5 1/4 2x layer dynamat all doors
AAAudio710 Posted July 25, 2012 Report Posted July 25, 2012 wanting to get a SA-8 V2 and wanna show people up and prove a 8 can be as loud as anything you throw at it and i know a T-line will doo problem dont know now to ago about making one let alone calculating how to make one i need help!!! 2007 JEEP COMPASSDC LEVEL 4 18"AUDIOQUE AQ 2000.1ELEMENTAL DESIGN NINE.4
1 Sock Posted July 31, 2012 Report Posted July 31, 2012 Hey man I read through the t line topic and wanted to build one instead of a ported box. Could you sketch me a design? I listen to slowed rap, bass mekanic, decaf.. Max dims in 98 dodge ram ext cab rear seat removed 50w 21d 40t. There is a little more room in height. I have two sundown E12 on order! their dual 4 ohm I was going to run one ohm final load My amp is a rockford T500-1bdcp 800w@1 ohm Sub specs: Fs 35.8hz Qes0.56 Qms6.79 Qts0.52 Le1.85mH Vas47.6L BL15.4NA Cms0.13MM/N Mms 156.6 grams Sens n/a 1w/1m Xmax 12mm one way Rms 400w Displacement .12ft cubed Please help with some sketch or advice I think this t line would be better and easier to build than a sixth order someone else had suggested to me. Thanks a lot, James Do you want it to be as big as your dimensions? whats more important to you the height or the width? you want the subs up or forward? I am new to this but I think I have a ok grasp. I need the practice on Sketch up.
severancej Posted July 31, 2012 Report Posted July 31, 2012 As big as my dims u could take the height of it up to 50" lets see something man! Sub up port driver side or sub up port up 98' dodge ram 140A alt Big 3 XS D2700 JVC kd-r310 Rockford T500-1BDCP 2 Sundown E12 Ported 4cubes 35hz Rockford P400-4 2 Infinity reference 3way 6x9 2 Polk DB 5 1/4 2x layer dynamat all doors
JAHLIEE L.E Posted August 1, 2012 Report Posted August 1, 2012 GREAT STUFF GUYS IN SIMPLIFYING HOW TO MAKE A T-LINE.....ONE QUESTION I HAVE AND CONFUSE IS THAT I CANT FIGURE OUT THE WIDTH OF THE PORT HOW WIDE SINCE YOU GUYS STRESS A GOOD POINT IN HAVING A CONSTANT PORT..ALSO HOW BIG CAN I MAKE A BANGING T-LINE FOR A 2001 CHEVY ASTRO I AM OPEN FOR SAMPLES N DRAWINGS , I APPRECIATE THE HELP..THX THESE ARE MY SPECS....... 1 - 12" ALPHASONIK MAYHEM PSW912.. FS - 35HZ SD - 10.5 QTS - 0.374 QMS - 1.485 PORT LENGHT - 8.071 PORT AREA 78.53 http://alphasonik.com/index.php/en/support/ts-parameters.html
412 CVX Posted August 1, 2012 Report Posted August 1, 2012 GREAT STUFF GUYS IN SIMPLIFYING HOW TO MAKE A T-LINE.....ONE QUESTION I HAVE AND CONFUSE IS THAT I CANT FIGURE OUT THE WIDTH OF THE PORT HOW WIDE SINCE YOU GUYS STRESS A GOOD POINT IN HAVING A CONSTANT PORT..ALSO HOW BIG CAN I MAKE A BANGING T-LINE FOR A 2001 CHEVY ASTRO I AM OPEN FOR SAMPLES N DRAWINGS , I APPRECIATE THE HELP..THX THESE ARE MY SPECS....... 1 - 12" ALPHASONIK MAYHEM PSW912.. FS - 35HZ SD - 10.5 QTS - 0.374 QMS - 1.485 PORT LENGHT - 8.071 PORT AREA 78.53 http://alphasonik.co...parameters.html lol draw it up yourself or pay someone to do it. This stuff isn't that hard when you learn it, but it takes more than 5 minutes to do. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
STEvil Posted August 1, 2012 Report Posted August 1, 2012 also please remove the capslock key from your keyboard MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
1 Sock Posted August 2, 2012 Report Posted August 2, 2012 As big as my dims u could take the height of it up to 50" lets see something man! Sub up port driver side or sub up port up Right around 36hz 50" X 27.25" X 17.5" E12 Cutout: Outside Diameter: 12 1/4" Depth : 6 1/2" Cut-Out: 11 3/16" Will take 2 4'X8' sheets of wood:
t-money Posted August 5, 2012 Report Posted August 5, 2012 y is there a section of the tunnel not calculated? when u see the line drawn down the middle. and how do you calculate what that should be for your application? 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056
