Cheeze975 Posted July 17, 2008 Report Posted July 17, 2008 Hey guys, can I use a sub for sealed application on a tline? I have an old school MTX Blackgold sub and was wondering if I could put it in a tline... I'm gonna power it with an old school HiFonics Thor VIII 400 watt amp, will this set up work or will it be a waste of time...
Cheeze975 Posted July 18, 2008 Report Posted July 18, 2008 Thanx... Another question is should I based it on the sub's Fs or Q??? Thanx...
EricM9104 Posted July 18, 2008 Report Posted July 18, 2008 Fs 2015 Honda Civic LX 4dr | 110k miles | Stock 1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
jhmeg2 Posted July 24, 2008 Report Posted July 24, 2008 Not to be a dick but your sig is fucking loooooooong. I suggest a 35hz tuning. Make sure you have the room for it, though. ok thanks I fixed my sig.... and I built the t-line for the 8.... WOW !!!!!!!!!! tuned it to 39Hz, and it peaks at 48 in the Envoy. It did a 134.9 on the dash 132.4 @ the head rest... Not to bad right, with 100 watts. Let me know what you guys think, oh and till i can find the time, i mean untill i'm not to lazy to build a t-line for the mojo, I slapped 8 10s back in. ////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
poundindak69 Posted July 24, 2008 Report Posted July 24, 2008 how about a sundown SD-1 v.2 10 here are some specs Qes = 0.437 Qms = 4.545 Qts = 0.399 Fs = 28.77 Hz VAS = 56.92 L Mms = 88 grams Cms = 337 uM/N RE = 7.31 ohms (series) BL = 16.55 N/A (series) Le = 2.13 mH (series)
Torres Posted July 24, 2008 Report Posted July 24, 2008 how about a sundown SD-1 v.2 10 here are some specs Qes = 0.437 Qms = 4.545 Qts = 0.399 Fs = 28.77 Hz VAS = 56.92 L Mms = 88 grams Cms = 337 uM/N RE = 7.31 ohms (series) BL = 16.55 N/A (series) Le = 2.13 mH (series) 9.84' long, about 60 sq inches of port.8.07' long with higher tuning (35hz) and 60sq inches of port
qu1cks1lver56 Posted August 5, 2008 Report Posted August 5, 2008 ok i pm'd foreverbumpin but i guess ill post my question here too. ive got 2 RF punch p1 10's that ive been thinking about building a t-line box for. but i have no idea where to start. heres soms stats on the woofers. Fs: 33hz Qms: 8.38 Qes: 0.59 Qts: 0.55 Vas: 1.568 FT^3 Mms: 3.84 oz Cms: 2.40E-04 m/N Re: 6.6 Ohms Bl: 15.4 T-m im sure some of that you might not need(?) so do i tune to 33hz? idk where to start any help is much appreciated First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
BigPimpin91 Posted August 6, 2008 Report Posted August 6, 2008 ok i pm'd foreverbumpin but i guess ill post my question here too. ive got 2 RF punch p1 10's that ive been thinking about building a t-line box for. but i have no idea where to start. heres soms stats on the woofers. Fs: 33hz Qms: 8.38 Qes: 0.59 Qts: 0.55 Vas: 1.568 FT^3 Mms: 3.84 oz Cms: 2.40E-04 m/N Re: 6.6 Ohms Bl: 15.4 T-m im sure some of that you might not need(?) so do i tune to 33hz? idk where to start any help is much appreciated I would recommend two serperate lines.If you can't fit them. Do a Line with both of them side by side. Tunning to 33hz would be optimal. Measure from middle of the surround on one side to the middle on the other, then, times that by two and you have your area. BigPimpin91's Banging Music
qu1cks1lver56 Posted August 6, 2008 Report Posted August 6, 2008 I would recommend two serperate lines. If you can't fit them. Do a Line with both of them side by side. Tunning to 33hz would be optimal. Measure from middle of the surround on one side to the middle on the other, then, times that by two and you have your area. im shit with designing a ported enclosure. say i gave you the dimensions i have to work with, think you could draw me one up? First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
