Quarter Wave / T-Line tutorial-UPDATED
Forevrbumpn
well if you can find all the needed specs for it to be built properly, but if it doesnt work out, the ox will basically be useless as the t-lines ave to b e built to specific sub specs, it mainly calls down to ability to do math and woodwork and budget, if you can risk wasting a box, then try it out
Hammerdown... 1%
  • 4 weeks later...
  • 4 weeks later...
one thing that i've seen but havent tried is what if the subs are at different lengths i thought i read that there would be major cancellation but i see it more and more.
so anyone that understands that bit more then me or has done it will you please help
I can't stop building!!!
4 DC LeveL 4XL 18 Blow Through Re-Build
The newest addition My '97 Ford Explorer Build
My First Build 8 RF P1 12's
My Myspace Add Me
My Facebook Add Me
oh, your a hypocrite too bro.....your mom has my name on her left tit - and you still like her dont you?
If youre masturbating to that sub already, wait until you get a real sub... I think your nutsack will shrivel up.
Thought I would just let u guys know im going to be getting back into these again. starting with my truck. I just got my 18s playing and already a voice coil is fucked and the box has major cancelation. So im rebuilding them into 2 18 in t lines. Tonight ill post up the desgin and whatnot. So who wants to see 2 18s in one regular cab blowthrough?
My Myspace Add Me
My Facebook Add Me
as the pic says i need help guys
My Myspace Add Me
My Facebook Add Me
What so u think about the section infront of the tlines its like a ported box that's ported into the cab. But the lines are ported into it so Idk how that's gonna work
My Myspace Add Me
My Facebook Add Me
can any one help me out with a t-line for a 15" Fi Q? im sorta new to the t-lines and ive heared alot of positive things about them so i wanna try for myself!
Fs: 32.1 Hz
Re: 1.4 Ohms/coil
Qms: 8.61
Qes: .44
Qts: .42
Mms: 299g
Cms: 0.82mm/N
Sd: 810cm^2
Vas: 75.6 l
Spl: 89.4dB 1W/1m
Bl: 19.65 N/A
Xmax: 28mm
Rms: 1000W
Sealed box: 2-2.6 cuft
Ported box: 2.8-4 cuft @ 28-33Hz
Sub OD: 15.625”
Cut ID: 14.125”
Mounting depth: 8.500”
Displacement: 0.19cuft
Look there go's that BASSHEAD!
This design here ends up being a tapped horn in a way, well it does.
In all honesty, it should perform well, even though the entrance to the cab is smaller than the line area, That may even be beneficial for creating port velocity. A opening this large shouldn't make a lot of noise as people think with all that talk about port noise/etc
BUT.... That 10cf chamber, I would cancel that out. Or make it temporary to just try a theory.
If you decide to build this with that 10cf chamber, please let us know how it works out
With that chamber this ends up being a kind of ABC box I believe?
  • Who's Online   0 Members, 0 Anonymous, 1178 Guests (See full list)
