the wiring mess they left me.
When Audiofanatics replied "I got you, gimmie a second" the first thing that went through my head was "dang, how bad does he want the OP's first born"? hahaha
Just kiddin' man. It's late and the thought just flashed through my head.
4 American Bass VFL 8" at 0.5 ohm
Soundstream Tarantula 3000.1D at 0.5 ohm
32 hz ported box designed by Mark at Car Audio Fabrications
XS D1200 secondary with Stinger isolator
Well if he can figure this mess out he deserves it . It's a mess the guide you have me right off the bar says the 12v power goes to yellow in the 10 pin harness at pin 6. Well it's in pin 7
yeah that's not a factory wiring job lol. that a know it all wiring hack job.
a good fix would be to go to a junk yard and get the wiring plug/connector and cutting that hack job off and soldering the wires from the junk yard connector to the stock wiring in your car. then you know the wiring is right. just make sure you cut the wiring on the junk yard part as long as you can so you have wire to work with. easier to take from then add to.
welcome to the forum
fyi, don't like your own posts, its kind of stupid/pointless. I mean we know you like your post otherwise you wouldn't post it or at least edit what you didn't like about it.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Did I really like this crap. Actually I hate it this stereo is driving me bat shit crazy. But yeah that's a good idea actually I'm looking for a double din to put in it and just do all new
even if you put in a new headunit I would still fix that wiring like I said then buy a wiring adapter for your truck so that the stock wiring stays and all you have to do is plug and play once you connect the wiring from the adapter to the headunit. its a lot easier that way then trying to solder wiring inside a small hole in the dash.
the reason for suggesting soldering is that it looks more professional and is easier to deal with rather then a big bulging clump of connectors.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Well I have it going from the stock Rockford heading, to a loc, to a amp then to two 10 in Audiobahn subs. It was working fine then all of a sudden the sun just stopped working, I opened it up and that's what I found.
looks like the kid who had my Durango before me wired your system to! it was a rats nest back there!. the deck had a total of 3 grounds and 2 power wires. not to mention i pulled 3 yellow wires that as far as i could tell didn't go to anything. some of the pins were pulled out of the connector. it was a 3 hour job just to get My new deck in(usually takes 30mins) works fine now but i had to run my own battery wire and kill switch since the deck won't turn off with the truck. he somehow cut the main battery wire from the harness but way back in the dash... i can't even explain it.
i guess i just want to say i feel your pain!
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
  • Who's Online   1 Member, 0 Anonymous, 1120 Guests (See full list)
