DC Sound Lab
DC Audio 3.5k Dyno Testing using Single and Dual Inputs
I just finished testing a 3.5k with the purpose of seeing the difference if any in using a single bare copper shoved into the amp vs 1/0 amp input and Dual 1/0 inputs.
I will be doing in vehicle SPL testing to see if there is a difference with these in an SPL test later.
http://www.droppinhzcaraudio.com/
Edited by CJ18
  • Like (+1 Rep) 5
Good test now I know I dont need them for my single amp
XS Power D5100, 2 D2700s, & 2 D975s
MechMan 220a Alt
DC 5K
Kicker 650.4
2 12 Ascendant Audio Mayhem's
Pioneer DEH-P7200HD
Rockford Fosgate 3sity.1
Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899
https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
True so Im waiting for the next vid then
MechMan 220a Alt
DC 5K
Kicker 650.4
Pioneer DEH-P7200HD
Imo you should have did the single run WITHOUT the block.
Obviously double the wire isnt in question. Double the wire is obviously better. The question imo is the reduced CONTACT AREA of using the distro block.
A single bare ended wire input into a standard amp terminal will have thousands of contact points to deliver the power.
By using a distro you now only have 2 points of contact going into the amp. Set screw against top of the block. Block against bottom of amp input..
So imo the test should be two fold.
Does a single run without the block differ than a single run with the block?
And what is the difference between normal single run and dual using the block.
No one buys buys those blocks just to continue running one wire... so really that test was silly.
You normally go from one single run to tm block dual runs.. which was not shown.
Redo plz.
Edit: grammar etc.
Edited by P4killer_
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
Redo plz.
Edit: grammar etc.
I did the test with bare wire vs the input and there was a 2w difference. If that is significant enough for you to want to see, sorry, I dont feel like testing it. I will do the same test jsut to disprove the people that think using an input vs not using 1 makes a difference.
Edited by CJ18
I see now that you were using a single 1/0 tm maker block at first. I thought you were using the dual with only one wire plugged in.
My bad on that. My question still stands as to surface area. I seen lots of people using tm 1/0 to 1/0 blocks just for cleaner wire. I wonder if theres any difference vs normal.
Setup:
Xs D3400/ Xs XP3000
