One Subwoofer Not Responding to Lows.
Exscathe
Oh you want me to respond to the rca comment. Ok here how's this well looks like you're back in the same boat then aren't you? Wiring or woofers
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yeah i know Derek but we are talking two woofers there shouldn't be any ssignal issues or anything over such a short run of wire. Especially if he's running to one terminal off his box. In the big multiple setups I've seen it as well
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
You've received tons of help you're just too stubborn to see it.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I have taken it and used it, the only thing i did not do was re wire to a different style of wiring in series, I am not going to wire it in series again as I have said on countless occasions and I am going to wire it to one ohm. Do you have any useful input for me besides wire it in series like this. I have said on multiple occasions that I am not going to re wire it to 4 ohms.
Then why do you continue to post about it if you are no longer going to have the same issue? Trying to prove you are smarter than those snotty Americans?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
DID YOU SWAP SUBS YET?
Seriously... Have you done this yet? You ignore what I say and choose to argue/get upset vs. Listen to the people that are actually trying to help you. Really doesn't make sense
where
are
you
located?
wire one sub up, pop test it. then wire the next, and pop test it.
its going to be an issue with wiring after the amp as most have said.
how old are the subs?
check the solder joints at the terminals see if they are still togeather. i broke a few, they were fine till the sub started really moving then the sub would loose power.
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
So when are you going to wire at 1ohm to see if you still have the problem?
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 1083 Guests (See full list)
