I am either going to hook up a second battery, different make and age, or use the second battery as my main. If I hook up the the battery in parallel like I plan to do I need an isolator if I don't plan on playing music with the car off? I don't want to kill one of my batterys. I'm running a 136 amp alt now. Any advice would be great.
An isolator will not let the battery contribute to the system and vampire your power away from it causing the alt unneeded stress, your best off to just add more batteries with no isolator, and you will have the extra capacity that your looking for.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Dont do it.
OK so no isolator. Thank you guys. I ended up getting a xs 925 to hook my amps up to. If I have a 0 gauge run from battery + to battery + do I really need to make a second Run of 0 gauge to the negatives on the battery's or can I do the big 3 and make a secure ground. Also should I going my amps the the body or the negative to my battery
Do the big 3 and ground the rear batteries to the chassis. Just make double sure all of the grounds are clean and tight. If the grounds are where the weather can get to them make sure it is protected from the elements with paint or dielectric grease etc..
  • Who's Online   0 Members, 0 Anonymous, 1934 Guests (See full list)
