Mixing CCA and OFC
^^^^^^^this copper is a better conducter I am running 2-2/0 per alt front too back battery's I believe I'm getting maximum current under load out of my alts
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
If your not a fan of bogging down engines with alternator power then I don't know if this is the right hobby. There is no magic alternator that produces crazy amps with out a certain amount of drag on the engine. It takes power to create power, <- true in every sense of the phrase.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Good luck with Singer, he is not the "God" everyone thinks. The Mechman alts are every bit as good
Customer service wise he is. Who else will answer my questions at 9pm on a Saturday?
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
I'm not goin to bash in here but I've run alts from a lot of company's an once they get big there quality goes to shit an so does customer service .. Mikes a great guy an I'll run his alts. Oh an let me state this you will never most likely see or have happen what my truck does .. I have 2000 amps of current draw on 990 amps of alternator
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
How did you measure that 2000 amp of current draw?
Forget alt output when running from the front batt to the back. Your battery can provide way more amperage than your alt can in most cases. You need enough wire to cover your total current draw of your amps and accessories that are hooked to your runs to the back. Your wire from alt to batt should be enough to safely carry what your alt can put out (i would go at least 25% over that)
And of course fuse for the wires rating on all runs except the runs from the rear batt(s) to amps. They should each be fused for the amp they are hooked to.
This thread has cleared up a bunch for me. I bought SHCA's CCA to run from my buss bars to amps, but Stinger HPM 1/0 OFC from front to rear. Thought I made a big mistake with CCA
2- 8 ks at .35 haven't clamped them but I know my amp does 8858w at 1ohm and 11 k at .5 Cj dynoed it . Help here from math guys? I'm half asleep
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 4316 Guests (See full list)
