Knu 1/0 370a alternator ok with one run?
But I can see multiple points creating heat on the stud time to change to 4/0
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
or do the 2 runs in one lug thing.
The one lug wouldnt do anything for the low bat thingy MM is talking about.
Id expect the entire bank to help "back fill" the low cell. If you saw a shitty resting voltage on your entire bank, reason would stand, you have a bad cell. :shrug:
maybe im lost?... yes.. i am. :twirl:
I kind of understand... so the resistance is only caused when there is a back flow form rear batts which heats the stud with "multiple" lugs. Therefore (somehow) heats the regulator? i'm in space. just floating...................................................................................................................................................................................................
I believe MM, just my brain don't know how to process it.
:ughdunno::deadhorse:
4 runs on each alt is completely not necessary and a waste
Not even trying to be a cock.. BUT...
Necessary?
For you.... maybe not
(you know Ray is one of the loudest non wall set ups on the planet right)
but 2 simple connections on the alt hot stud shouldnt be all that big of a deal.
Most, are told to add a larger gauge, WITH your OEM line. Is that not 2 connections?
Again.... .. i have 2, wait! i have 3 ISH due to my VCM ... so..... maybe im burning my regulator up?
Ive never seen a issue but shit...
i think the heated stud argument relies on the alt stud being the central connection point between rear and front batteries. If I am following this correctly.
Not everyone is wired the same. I have 2 runs off of the alt but its going straight to my rear bank then from there through step downs to a small 12v in the front.
I assume this makes me "safe" ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Nope.. the 2 connections on the one stud is the issue where are talking about now... Where they go dont matter.
We are speaking of 2 connections at the ONE alt stud.
  • Who's Online   0 Members, 0 Anonymous, 808 Guests (See full list)
