Knu 1/0 370a alternator ok with one run?
I have a mechman 370A elite and was told by mechman that you should only have one run from the alternator as multiple connections can cause resistance and overheating of the alternator.
My question is, would a 16 inch run of Knu 1.0 be sufficent on the 370a to the front battery? just curious before I change anything.
I know the wire is rated for 300a.
Its rated at 300amps at 20ft so it would probably be fine
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
i really want to hear the explanation as to how adding more than one run from the alternator + stud to the battery will harm anything. loose connections will increase resistance sure, but if you know how to fuggin solder or crimp, and tighten things down, then there are no issues.
Even if its rated at 300A.. Thats at like 20ft. Your run isn't even a foot and a half.
Its unbelievable how much power can run through short 1/0 runs.
You're good.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Yeah, mine are hydraulic crimped lugs w/ heat shrink.
Just going by what I heard/was told. Not trying to bash anyone.
whaaa? more wire and more copper terminals = more resistance???? that's a new one.
Not the wires, the multiple ring teminals stacked on the stud is what they said.
I noticed some others wondering the same thing on here the last few weeks.
You DO NOT want to stack terminals on the alternator. Stacking ring terminals on the alternator WILL cause the regulator to overheat..
  • Who's Online   0 Members, 0 Anonymous, 4424 Guests (See full list)
