Alternator runs to battery?
My truck is stock with dual battery's.
2 d3400s
Singer 275amp alternator
Stock wiring is only alternator to passenger battery.
Should I add an additional run from alt to the driver side battery? Or would just one run to one battery be okay?
Also big 3 is done underhood if
Singer 250
2 d3400s up front
Xp3000 rear
2 dc xls 12s m2
AB VFL 500.1
Id do Singer to pass batt in 1/0
Then pass batt to driver batt in 1/0
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Id do Singer to pass batt in 1/0 Then pass batt to driver batt in 1/0
That's how it is currently wired.
Would wiring the singer to both battery's help charger both battery better?
from what mechman says is that its best not to run multiple wires from alt to batts. something about overheating.
you most likely wont see an increase in voltage except at that one battery anyways so the cost just wouldn't be worth it imo.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I doubt you draw enough current to make a difference.
LMFAO so true
:blush:
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
