Your last reply to me answered your own question then lol
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
I would dd both of them though. Find out which amp has the lower voltage out clean and use that as my master. If you have the higher voltage as your master you may cause the other amp to put out a slightly dirty signal. It probably won't be much but if you are going through all that trouble might as well cross the ts and dot the is
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
True, but unless you use the 0db tone you will have overlap anyway and still risk clipping.
But n8's idea is smart
Edit. I meant to say 0db tone
Edited by strangeduck
The positve output is on the master amp. Just dd1 that amp while they are strapped and you should be fine.
Just don't use track 7
quick question here . the amps are the new sundown 5k so when i check the power out from the master do i need any thing else connected to the speaker out ? only reason i asked is i followed the sundown diagram on how to strapp expect i forgot to connect the negative speaker out form master to to slave and the subs went crazy lol.
i already did that lol.
when i tested the amps single 1 to each sub i set each amp with the dd-1 and to the eye both gains looked identical and when i checked with the meter thy were with in a tenth of each other .
and btw i am using track # 3
