Differences in Sq hds200 and sdc2.5
iKidwell
Alright, so i've been looking at doing a little something in my infiniti now and soundqubed has caught my attention, i originally thought i wanted to do either a single 12 or 15 hds300, but then remembered how much i loved the aq sdc2.5 15 that i'd had a while ago. I also saw that i could still buy the sdc's instead of the hds200's, but they're a little more expensive and i'm not sure if it's worth doing.
The main reason i'd want the sdc's is because of the basket over the basket of hds200.
Main question here is: What are the main differences in the sdc2.5 and the hds200 series from SQ?
And: In your opinion is the $11 extra worth spending on the sdc2.5
Note: I want to know physical differences
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
In for the answer. I know I have the newer hdc3 which has a different basket.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Imo first the 2.5 and the 200 are pretty much the same sub becides the cosmetic things they did change tho was the 2.5 was direct leads where as the 200 has terminals now. I also feel they actually rated the 200 like the 2.5 should have been. Other then those I'm kinds in for a answer my self. There both still great suns and the $11.00 difference should not matter Imo. I personally would get the 3000 or the hdc3 muhahaha
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
So you think that the suspension and motor from the sdc's and 2007 are the same? And if the 300 in 15th were in stock I'd get that
Build in Progress
this is the exact email they sent to me only i asked them a different qustion. this is some info they dont have on their site
edit: hope it helps
SQ Tech [email protected]
12/12/13
to me
Andre,
The HDS2 has a 2.5" coil with two spiders, and the HDS3 has a 3" coil with two spiders. The HDS2 supports a 100oz magnet with the HDS boasting a 140oz magnet.
The HDS2 has a stamped frame and the HDS3 a cast.
Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird..
He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke.
2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe
subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12
Amp: pioneer gm9061 amp: poineer gm9601
headunit: kenwood kdc 255u mids: SQ pro mids
midbass: polk db 8s highs: stock
mids/highs: shitty off brand
From 2007 hell no lol but from 2012 pretty Damn close will say. Hopefully AMI will see this and be able to answer better then I can.
141 on music.
Meant to say 200's, phone typo lol
Build in Progress
Why not get the 300 series. my god they aren't that expensive. you can't go wrong with a 3" coil.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
I'm just not gonna have the power that they're going to want
Build in Progress
the 300 series still sounds good underpowered and leaves room for future upgrades. mine are are sharing "1200"rms (saving up for better amp) so realistically 500ish per sub and sound good.
  • Who's Online   0 Members, 0 Anonymous, 3164 Guests (See full list)
