alaskanzx5 Posted April 23, 2014 Report Posted April 23, 2014 Yes like that, some killer work right there. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
john253a Posted April 23, 2014 Report Posted April 23, 2014 Only down side is The wave from sub and port Aren't they ment to be as close to each other as they can + both on same side/same direction
revoracing247 Posted April 23, 2014 Report Posted April 23, 2014 Only down side is The wave from sub and port Aren't they ment to be as close to each other as they can + both on same side/same direction i have heard that before but im honestly not too worried about that. it'd be like saying that on a box for 2 subs they should be as close as possible. it's cause the wave from the port is just in phase with the sub. so putting them really close just means the waves are being emanated from one point instead of two slightly spread apart points ~ If it was easy, everybody would be doing it ~
Dude2800 Posted April 27, 2014 Author Report Posted April 27, 2014 I left the 45's hollow. I've heard several different arguments. If you do nothing it sounds better, if it's perfectly round it sounds better. I 45ed it.
Dude2800 Posted April 27, 2014 Author Report Posted April 27, 2014 The box is HEAVY. It has to be close to 300 pounds, probably over with the sub. Luckily, I have a strong wife.
Dude2800 Posted April 27, 2014 Author Report Posted April 27, 2014 It almost didn't fit. I didn't take this measurement into account cause it had so much head room.
alaskanzx5 Posted April 27, 2014 Report Posted April 27, 2014 Umm, didn't expect it to go in like that lol. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Dude2800 Posted April 27, 2014 Author Report Posted April 27, 2014 Didn't see a panel piece when I took my measurements. No biggy. I'll lift the box or cut the panel.
