Question on my electrical
2/0 sky high IMO if you are bent on only doing 1 run
You need to consider front-back voltage drop. Not just the wire's thermal capacity
0.52V with the 0guage wiring and 0.43volts with the 2/0 guage wiring. (that's with a 300A over a distance of 9ft , which seems a bit more then what will really happen)
Not really something that would make any difference. (0.09V...)
Start at 300a and see how that treats you. I'm leary of going any larger because you have stock batteries and alt. Any larger and I think you'll run the risk of the battery and/or alt not being able to supply enough power to blow it in a reasonable time
All you have to do is fuse at the wire rating, the fuse is there to stop your wire from burning.
A 300 amp fuse on 2/0 guage wiring won't stop him from blowing the amplifier if he isn't careful.
OP:
You will need a upgraded alternator with a minimum capacity of 200 amps, obviously choosing one that is 250 or a bit higher won't change the cost a lot but the price/performance will increase dramatically.
my question is will I be ok with the 0awg with a 250 amp fuse cause I really don't wanna have to order new fuses and wire since i already have all my fuses and wires upstairs :/
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
No, not if it is CCA wiring, if it's OFC wire then yes.
But you can fuse higher then 250A with OFC and you will probably need to since both those amp can draw over 250A at full power.
so what wire and fuse will I need for the 2500 and my TMA 440.4 it takes 50 amps
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
What about another run of 1/0.
i wanna stick with 1 run cause idk how to do 2 runs or how it works . :/
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Running 2 is the same concept as running one. The only extra "pain" is finding space.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
ok we'll I have to run 2 anyway right if I'm doing a back battery so I guess I'll do 2/0 so I only have to run 1 pos to pos and 1 neg to neg to the back battery ?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
OP:
Regarding voltage drop: You are forgetting to account for the fact that car audio wire is oversized. With 0 gauge being closer to 2/0, and sky high's 2/0 being closer to 4/0. That is also voltage drop purely across the front-back wire, and doesn't take into account things like connections, wiring post-distribution block/battery, grounds going out of the amp, or the voltage drop across the frame. Your real world voltage drop will be a lot more.
If I plug in a 15ft length of wire(front-back + ground length + rear batt-to-amp length), 300a load, and a wire temperature of 60C: I get the following
2/0 Alumnum: 1.36v
2/0 OFC: 0.83v
4/0 OFC: 0.52v
That's roughly a .2v difference between the 2/0 and the 4/0. Pretty significant IMO. Dropping to 12.6 vs. 12.4.. 12 flat vs 11.8. Etc. And those rockford amps really don't like low voltage. With OP's electrical he'll need every bit of help he can get..
Regarding fuses:
The fuses we use in car audio are referred to as "slow blow" fuses. You can run more than rated through a fuse and it will take some time to blow. Can't find the thread, but a member on here ran a stupid amount of power through a 300a fuse during a comp and it didn't blow. The fuse was all discolored from heat, but yet it didn't blow.
Quick review on ohm's law
I=V/R
Current = voltage/resistance.
V=RI
Voltage = Resistance * Current
Stock batteries aren't really known for being low resistance. That's why we upgrade them. High internal resistance in the battery = heavy voltage drop under load. Holds true with V=RI
Now if we take a look at our current equation, I=V/R. If you lower the voltage (battery voltage drop under load) and your source of resistance is the short, wire, connections, fuse, return path, etc. It could take an extended amount of time for the fuse to blow. If at all. Hence why I said to err on the smaller side of a fuse rating.
Also consider that with OP's electrical. Stock alt, stock battery. I doubt he'll be able to pull 300a through his front-back run. I see something more like pulling ~200a from the front batt+alt, ~100a from the rear battery
OP:
2/0 Alumnum: 1.36v
2/0 OFC: 0.83v
4/0 OFC: 0.52v
Regarding fuses:
I=V/R
V=RI
so what do you reccomend me getting could u give me a step by step on what I should get ?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
  • Who's Online   0 Members, 0 Anonymous, 1111 Guests (See full list)
