dual sub shared chamber question
randyman78596
what u think about those specs??should i have placed the subs in a different spot on the front panel??if the subs have a different degree of break in will they both eventually get to the same level of a 'maximum' break in??
so what could the explanation be for the little more excursion ?? im just wondering... i also put my ear to each sub while playing and noticed that the one closest to the port played a little lower. this is kinda a trial for me, learning what to do and what not to for future box builds...
The explanation could be that one sub is unloading and the other is not. I highly doubt that is the case though. Does it sound good? Are you worried that it could loser if both subs were moving exactly the same?
i have had quite a few setups of different sizes, single and dual setups, prefab and custom, sealed and ported and none have hit all the notes like this setup...this one doesnt seem peaky with certain notes...whether it be high or low notes it sounds like the same volume through them all...i can notice that one sub close to the port moving more though lol. i have ocd or something..
If you swap the subs and it happens the same then is likely unloading, the box specs are fine and is correctly laid out with an extension length of 8" as you described.
The way to avoid potential unloading issues is doing the box like this:
kool Joe i gotcha man i will swap em around and see what happens, thanks and next time i will stick to the center ported... also while u are around and cause i dont wanna start another thread...i have a sundown e8v3 i want to build a tline for..i have 2 pieces of mdf that are 24" X 48" and one pice that is 36" X 44" ...i have 44 inches width to work with and pretty much unlimited depth and height...u got a design u could help me with??
this is a hot topic come on now!!lol..anyone had luck building a quarter wave t-line for a sundown e8v3?? if anyone could help me out that would be appreciated. i have 44 inches width to work with..all i need to know is simple dimensions i can figure the rest
  • Who's Online   0 Members, 0 Anonymous, 3164 Guests (See full list)
