A couple questions about strapping two amps...
I plan on strapping two amps together for one of my subs. The questions are as follows:
1) Will strapping the two amps together do anything to the resistance of the sub? It is a dual 1 ohm. I know each output from the amp goes to each voice coil of the sub.
2) Will the remote gain control the gain for both amps at the same time?
3) Does each amp need to be tuned separately from the other? Or does the datalink cable do that for you? I guess I'm just not aware of exactly what data the datalink transfers between the two amps.
4) When putting one amp into slave, does it also make the output signal 180 degree shifted from the master amp?
i know the sub ohm doesn't change, each amp will see .5ohm
as far as gain control the bass knob on my jls controlled both when i had them in master and slave. they weren't strapped just M\S. and my one amp controlled the others eq settings.
and i don't think it would change the phase. again mine didn't. i can't say for your amp but mine didn't.
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
Wrong. Your amps will each see half of your final impedence. If you strap at 1 ohm both see .5 if you strap at .5 both will see .25.
If you strap most amps will be controlled by 1 knob.
phase typically doesn't shift. I don't know what amp you are using but I'd check the manual for how to properly strap them. If your manual doesn't have that info I wouldn't try it
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I'm wrong? he asked if it changed the ohm at the sub, i said no. and if he strapped at one ohm he would see .5 on each Amp. it will change the Load yes but not the subs
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
How do you strap a dual 1 ohm woofer at 1 ohm
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yes you can. The amp doesn't care how you wire your woofer since it only sees the load presented.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
You can't get a final impedance of 1 ohm with a dual ohm woofer. You can get .5 and 2 I'm not talking about what each amp would see. I'm talking about your final impedance presented to the amp.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 725 Guests (See full list)
