KiKaZz74 Posted March 3, 2014 Report Posted March 3, 2014 So this bitter cold sucks. My trucks heater also suck. Anything I can do to get alot more heat out of it? My moms new journey heats up and blows hot heat at full fan in 5 mins. I can do 2/4 and get barely warm heat with it fully warmed up. Any higher it starts blowing cool air. Idk what to do. Mechanic backflushed and drained it. I blocked off probably 2/3 of the radiator to try to get some heat. But even then it still takes 15+mins to get good warmish air. Cools way down at stops. Please guys. Anything little tricks you know to help it warm up faster or putout better heat? Thanks My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
hammiethebasshead Posted March 3, 2014 Report Posted March 3, 2014 how's your thermostat. and what temp is it. once you get a speaker moving so hard that its possible to make tinsels slap, you are already kissing "SQ" goodbye. Don't get me wrong, as I smoke Marlboro Reds, but if I saw one more kid with that smug-ass look (Look at me I'm smoking indoors) on their face, I was going to shove that thing so far up someone's ass that they'd look like a hillbilly trying to understand quantitative prediction theorem. You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
KiKaZz74 Posted March 3, 2014 Author Report Posted March 3, 2014 It was good a few months ago. And somewhere around 190. I was thinking about that. Get a higher temp on like 210 220. My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
hammiethebasshead Posted March 3, 2014 Report Posted March 3, 2014 190-195 failsafe is what you need in your truck. that's the first thing I would check. if it's not that then it might be your heater core once you get a speaker moving so hard that its possible to make tinsels slap, you are already kissing "SQ" goodbye. Don't get me wrong, as I smoke Marlboro Reds, but if I saw one more kid with that smug-ass look (Look at me I'm smoking indoors) on their face, I was going to shove that thing so far up someone's ass that they'd look like a hillbilly trying to understand quantitative prediction theorem. You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
Popwarhomie Posted March 5, 2014 Report Posted March 5, 2014 Air blend door couldn't be messed up. Or heater core needs replacing. Check the hoses going into and out of the heater core when truck is warm. If they are both the same temp the heater core should be flowing fine. If the inlet side is hot and outlet side just warm it could be clogged. 2010 Focus coupe- 8 12" wall. 157.5@46hz 2016 Focus ST - SQ build.
KiKaZz74 Posted March 6, 2014 Author Report Posted March 6, 2014 It was backflushed a few months ago. Our mechanic said a shit load of gunk came out. Could be clogged again? Had damn good heat and was warm within 4-5 mins. Ladyed for a month or so and went back to slow and just warm. Maybe backflush again? My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
hammiethebasshead Posted March 6, 2014 Report Posted March 6, 2014 yea I would say backflush again. and see if it helps once you get a speaker moving so hard that its possible to make tinsels slap, you are already kissing "SQ" goodbye. Don't get me wrong, as I smoke Marlboro Reds, but if I saw one more kid with that smug-ass look (Look at me I'm smoking indoors) on their face, I was going to shove that thing so far up someone's ass that they'd look like a hillbilly trying to understand quantitative prediction theorem. You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
crispy_chick3n Posted March 8, 2014 Report Posted March 8, 2014 have you ever put any stop leak bullshit in the radiator? if so there is your problem. , especially if it was the kind with the metal flakes in it, usually the sealer will work too good, and either restrict the water pump, or destroy the water pump This page is crispy_chick3n approved. © crispy_chick3n inc
ParDeus Posted March 16, 2014 Report Posted March 16, 2014 Backflush again. If that don't work, put 48deg of timing in it. It'll get hot, trust me!
B-Large Posted March 23, 2014 Report Posted March 23, 2014 Flush the hell out of it! Never tried it myself but have heard of filling the core with clr and soaking it to help remove deposits.
