Skax Posted March 5, 2014 Report Posted March 5, 2014 was wondering how to make it difficult for somone to steal my 2500bdcp if somone decides to bust my window one day even though the seats will be up and in the trunk any ideas? just rather be safe then sorry 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Swordlordboy1234 Posted March 5, 2014 Report Posted March 5, 2014 Strip out the screws used to put the amp in. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
OrzechNJ Posted March 5, 2014 Report Posted March 5, 2014 mount it under the box or between back seat and the box.. or use the t-nuts you will have a hard time undoing them for sure lmao sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
Skax Posted March 5, 2014 Author Report Posted March 5, 2014 Strip out the screws used to put the amp in. how will i go about getting it out when i decide to take it out if i ever do 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
BLuejoules Posted March 5, 2014 Report Posted March 5, 2014 Strip out the screws used to put the amp in. lolllll. Use torx screws? IG: devinthydude
Swordlordboy1234 Posted March 5, 2014 Report Posted March 5, 2014 You can it back out using a stripped screw tool. Basically it grabs even a stripped screw head. Only good for one use in this instance but it would take a lot of screws to cost more then the price of said amp My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Skax Posted March 5, 2014 Author Report Posted March 5, 2014 Strip out the screws used to put the amp in. lolllll. Use torx screws? think im ganna just do that looks difficult enough for the average person around my area to get out 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Kyblack76 Posted March 5, 2014 Report Posted March 5, 2014 Set your alarm to the "on" position If they want it, they'll get it. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Swordlordboy1234 Posted March 5, 2014 Report Posted March 5, 2014 Strip out the screws used to put the amp in.lolllll. Use torx screws? If I was a theif I'd have your shit then. Mechanics son. I got almost every small tool people would actually need or use always in my car. About the only thing I don't have for handheld tools is the tool I mentioned. (To pull stripped screws) My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Skax Posted March 5, 2014 Author Report Posted March 5, 2014 Set your alarm to the "on" position If they want it, they'll get it. lmao kyle you make my day 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
