Added some bracing to front and rear baffle. No more flexing box. Gotta get 4 ch hooked up still and then im going to be adjusting my port some. More port area is needed I can already tell.
11149285_1054801811201828_30319913981452
"Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21
PIONEER DEH-P8400BH
2 CROSSFIRE C5 1700D
2 CROSSFIRE C7 18
HOOD. NSB GROUP48 TRUNK SMS AGM400
DUAL RUNS X SCORP 1/0 OFC
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
First video uploaded moving a little air. I just pulled the front baffle off today and am redoing the port. Pictures maybe uploaded tonight or this weekend.
https://youtu.be/colH4CgC-_E
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
Opening the port area up some as you can see, also got a shot of inside the box. Not sure I uploaded any with the 45 deg corners and everything caulked and sealed up. Unfortunatly the net air space I have to work with is going to leave me tuned a little higher then I wanted but I think its really going to help let the bass unfold better playing a wider range of frequencies. We shall see I know I will be louder! :P
11138589_1057519354263407_64407814924243
11149429_1057519290930080_84606841050756
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
You really shouldn't mess with ge box til you seal it off. You're goigg to change everything and then seal it and have to do it all over
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
I wont be gluing the front baffle or doing any resin until I finish the wall and then see where I am at on a term lab. Then I will be making changes I am sure. The front baffle is easily removable if changes need to be made. First wall, so im a noob but thanks for the input . Help is needed.. Lol
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
They finally came today! CNF sure does make some sexy ass terminals. Love them, worth the 2 month wait i suppose. B)
11156321_1058736707475005_77857491532175
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
  • 1 month later...
Alot has changed since i have posted. Did a event a few weeks back and hit some disappointing numbers but now she is completely sealed up she is a beast and hitting hard. Singer alt came in today and will be getting it put in and gonna see 150s here in the next event for sure.
10998389_1087813327900676_68305717898741
11393094_1087719947910014_67454560876488
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
Just went through the log and this is very impressive for a first build! couple things i noticed
1. You were worried about batts being charged, now you have the singer you should be good but i was going to suggest like this, connect the rings to the batt, run the plug to the bumper or something, then just connect the plugs to keep topped off. I have the connector with rings on my car, extended the wires to my bumper, wall plug plugged in and wire just ran under the garage door and connect when i get home for the night. Probably don't need to every night but I don't think it would hurt since the charger shuts it self off
http://www.oreillyauto.com/site/c/detail/BTD0/0220185GDLWH/N0360.oap?ck=Search_N0360_-1_-1&pt=N0360&ppt=C0371
2. You said you wouldn't be able to wire to 0.5ohm. Since your subs are dual 1ohms then you can parallel both coils on one sub to one amp, therefore 0.5ohm at the amp. You'll just have to use a multimeter to match the gains. DD1 the two amps first, get the voltage readings, the set both amps to the lower of the two ratings that way they're even and not distorted.
Keep up the good work man
I have had no issues keeping the batteries actually fully charged. every time i put a AGM charger on the batteries it read 100% fully charged but typically before events i like to put them on the charger to be sure. Great idea btw on the plugs to easily charge them. I have been running each sub on each amp @.5 ohm load gain matched. Like you said i used DD1 and went with the lesser of the 2 voltages with DVM and matched them. Used the Crossover on the HU only thing i cant really match is the Sub sonic filter. Need a CC1. Other then that im ready to wrap the wall and start cleaning it up. Thanks for the input and comments.
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
