xxgokouxx Posted March 6, 2014 Report Share Posted March 6, 2014 Hi, I've been trying to get into contact with steve to see what his input was on his system on his Lexus. But the shop said he's a private party and he owns his own side shop next to the shop I called... I didn't want to bother them any further. I didn't externally regulate my alt, in hopes of good results, but I seem to be stuck at the same voltage ratings, just the voltage kicks up faster upon RPM cycling upwards. I'd say my voltage @ 500rpm ranges from 12.9V-13.4V, and if I accelerate up. At COLD crank, I get a good 14v, after warmup, I can't seem to get past 13.5-13.7v. I'm currently using a Optima Yellow Top for my setup, I've ran in parallel to the OEM system, a 1/0 gauge wire from the alt to batt, and 1/0 gauge in parallel from the alt to the chassis. I can also take photos if it helps anyone figure out what I mean. FWIW, resting voltage on my Optima's surprisingly pretty sucky IMO. It rests at 12.3-12.4V, apparently the autoparts store I purchased the battery at says that 12.4v is a GOOD resting voltage. I argued about it for a bit and got nowhere, so I gave up and left. The battery was rated for 750 CCA, and it measured 734 CCA on their battery tester.... Any input outside of the battery would be greatly appreciated, thanks! Quote Link to comment Share on other sites More sharing options...
MECHMAN Posted March 6, 2014 Report Share Posted March 6, 2014 We do have an AVBM (adjustable voltage boost module) for that vehicle Which would give you the adjustment from 14-16 volts Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
xxgokouxx Posted March 6, 2014 Author Report Share Posted March 6, 2014 I've read from Steve's forum that CELs were kicking off while he was trying to adjust, that's why I didn't buy the module. Will I get CELs if I go that route? Thank you! Quote Link to comment Share on other sites More sharing options...
hankfan79 Posted March 27, 2014 Report Share Posted March 27, 2014 I've read from Steve's forum that CELs were kicking off while he was trying to adjust, that's why I didn't buy the module. Will I get CELs if I go that route? Thank you! Did you get a response or no? Quote Link to comment Share on other sites More sharing options...
xxgokouxx Posted April 6, 2014 Author Report Share Posted April 6, 2014 No response, I didn't call in though, I was waiting ehre and hoping I'd get a response via forums. Guess not Quote Link to comment Share on other sites More sharing options...
AA98hoe Posted April 6, 2014 Report Share Posted April 6, 2014 Singer says one for my lexus should work perfect contact him Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
xxgokouxx Posted April 6, 2014 Author Report Share Posted April 6, 2014 Do you have Singer's contact information? Thank you AA98 . FWIW, I'm still new to this stuff, and I've only gone so far with my system right now. Thanks! Quote Link to comment Share on other sites More sharing options...
SnowDrifter Posted April 6, 2014 Report Share Posted April 6, 2014 TBH I'd say this is normal. Newer Toyotas/Lexuses charge really low. Not a bad thing though. It's easy on your batteries Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
xxgokouxx Posted April 6, 2014 Author Report Share Posted April 6, 2014 TY for the feedback SnowDrifter I'm at the same time glad and NOT glad about the whole issue. I'm not happy I'm dipping down to 12v when I'm about to put 1400w+ (CT Sounds at1400.1d). I don't think my compressors like sitting at anything lower than 13.5v either . The worst part of all this is I don't have the funds at the moment (moving within the next month) NOR do I have room for a battery array Like in Mr Meade's car .... Quote Link to comment Share on other sites More sharing options...
hdorre Posted April 6, 2014 Report Share Posted April 6, 2014 (edited) The worst part of all this is I don't have the funds at the moment (moving within the next month) NOR do I have room for a battery array Like in Mr Meade's car .... Adding batteries wouldn't solve your problem anyway. Edited April 6, 2014 by hdorre Quote On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread Link to comment Share on other sites More sharing options...
