What sub should I get??
SirJimbles
But seriously I was thinking about a level 5 18 but was not sure if i was under powering it.
You should have started with that. That amp will push a lvl 5 very nicely. With proper gains set, you could get away with a DC XL.
But the more important question is if you can sustain that 2500 watts of power.
Alternator, battery(s), wire, everything needed to keep you from hurting your equipment and playing right.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Just pick one and build.
Also I am aware that is a serious woofer. I am also looking at Fi bl, btl, SQ hdc4 or an hcca 15.2
All of those subs will do great on that amp. Build the proper box which sub you get and you'll be fine. Also make sure you have enough electrical to run the amp.
You'll have to find out how much amperage your alternator can put out, describe the battery along with how long the run(s) will be.
Someone here might stay up and help, but I'm passing out for the night.
Well right now the batts. Stock but eventually ill upgrade to a pair of yellow tops or some other deep cycle batts. And well the suburbans a big car so probably around 10-12ish? feet
Also im not sure how many amps the alt puts out but ill check tomorow.
  • Who's Online   0 Members, 0 Anonymous, 3225 Guests (See full list)
