hondakid1996 Posted March 19, 2014 Report Posted March 19, 2014 Single stage is paint with a catalyst that drys to a glossy shine. Normal paint or 2 stage is a dull base coat covered in a high solids clear to add shine and protection. As for flexible block, meaning a sanding block that can bend to contour your box. Edit: ninja'd lol
OrangeJuiced Posted March 19, 2014 Report Posted March 19, 2014 Here is a write-up I did on show quality paint on a subwoofer enclosure. Not as easy as it looks. It also requires a ton of work, equipment and knowledge. It will be much more difficult on a fiberglass enclosure because of all the contours. If you decide to do it, take your time and good luck! http://www.stevemeadedesigns.com/board/topic/156909-how-to-show-quality-paint-on-an-enclosure/?hl=+show%20+quality%20+paint 2001 GMC Sierra Build. Body dropped and Juiced
john253a Posted March 19, 2014 Report Posted March 19, 2014 Another thing to add Is make sure what ever paint and high fill you use has flexiadd in it or is designed for plastic/Fglass As the will need to move and flex as the box does
ModernDayHero07 Posted March 19, 2014 Author Report Posted March 19, 2014 Ok thanks everyone. I'll let you all know how it turns out.
