Cable difference question?
I was wondering what the difference would be between car audio battery cable and regular battery cable. Like 1/0 gauge. Is there a difference in the individual copper strand diameters or is it just the insulation type?
97 Buick LeSabre with stock 140 amp alternator
XS Power D3400 (under the hood) using pdb distro blocks
Big 3 done with 2/0 ga welding cable
Alpine CDE-HD149BT head unit
CT Sounds Meso 6.5" components
CT Sounds 60.4
CT Sounds 1400.1
Fi Q 12 D2 with cooling in 2.5 net tuned @32 hz (box built by Sound Mekanix Customs)
Bunch of Sky High 1/0 ga & 4 ga cable (plus fuse holders)
Connection BT2 & BT4 550 (Audison) RCA's
Bunch of Mojo Mat
Like the difference with a battery cable for heavy equipment that's 1/0 gauge and a 1/0 gauge car audio cable. I have bunch of big cable laying around and if I could utilize it, good save some cash. Like I have bunch of different 1/0 gauge cable around that when cut in half one has thick individual strands of copper, while other cable I have has thin individual strands but there a alot more strands. While both are 1/0 gauge.
CT Sounds 60.4
CT Sounds 1400.1
Bunch of Mojo Mat
"Car Audio" cable is oversized. The good CA 1/0 is comparable to 2/0 welding cable or 2/0"awg". It also has a more attractive and more flexible jacket. It will also be a higher stand count making it more flexible to facilitate tight installs that you might run into in a CA environment.
But as far as ampacity... it's the same shit.
Thanks guys, pretty much answers my question. Other than looks and flexibility. Nothing really different with the insulation? As in thicker for car audio.
CT Sounds 60.4
CT Sounds 1400.1
Bunch of Mojo Mat
Looks like I might be able to save some cash because for the most part I only care about performance in trunk.
CT Sounds 60.4
CT Sounds 1400.1
Bunch of Mojo Mat
  • Who's Online   1 Member, 0 Anonymous, 612 Guests (See full list)
