PortSideAudio Posted March 16, 2014 Report Posted March 16, 2014 Is it safe to run a Q1-1200 at .5 ohms, currently I am just running off of the stock batter, I will be getting a XS Battery soon, but not right away. Also how much power would it be putting out at .5 ohms? 2002 Toyota Corolla Pioneer DEH-80PRS Soundqubed Q1-2200d Soundqubed HDC3.118 Soundqubed Q4-120 Alpine SPR-60 Alpine SPR-60C
Guest Posted March 16, 2014 Report Posted March 16, 2014 do it and see what happens. nobody can tell you if it will work or if it will even play.
Noel989 Posted March 16, 2014 Report Posted March 16, 2014 do it and see what happens. nobody can tell you if it will work or if it will even play. I like your idea Build Log - http://www.stevemead...-cruiser-el-pt/
PortSideAudio Posted March 16, 2014 Author Report Posted March 16, 2014 do it and see what happens. nobody can tell you if it will work or if it will even play. Well I either get the D1 or the D2 sub, I know people have run it at .5 ohms for years at a time, but I don't know if they did it right off of the car battery or not 2002 Toyota Corolla Pioneer DEH-80PRS Soundqubed Q1-2200d Soundqubed HDC3.118 Soundqubed Q4-120 Alpine SPR-60 Alpine SPR-60C
PortSideAudio Posted March 16, 2014 Author Report Posted March 16, 2014 my main issue is not running it with an extra battery 2002 Toyota Corolla Pioneer DEH-80PRS Soundqubed Q1-2200d Soundqubed HDC3.118 Soundqubed Q4-120 Alpine SPR-60 Alpine SPR-60C
CleanSierra Posted March 16, 2014 Report Posted March 16, 2014 You'll assume the risk of blowing it. Snowdrifter has a great response for this. It all comes down to if it's right for YOU. Are you ok assuming the risk that if the amp fries, you can replace it? Are you prepared to replace your sub/subs if the amp takes them out in the process? No one can tell you if YOU RUNNING half ohm is a good idea, is a decision you and you alone have to come up with and pull the trigger. On a side note, be prepared to feed it power. I don't think just one battery would make ME comfortable running half ohm. I don't think relying on impedance rise would make me comfortable that it would rise above 1 ohm and be safe for daily. What purpose are you trying to achieve running that amp at a half ohm? Are you just needing some extra power? Buy a bigger amp, run it at one ohm and be done with it. Or add a second battery to feed this amp at half ohm and set gains properly. Im not the one you want to try to troll. Just a fyi for you.
Kyblack76 Posted March 16, 2014 Report Posted March 16, 2014 Yup.. hell run it at .25. Its all the same around there, and the same about you being able to lose it at a given moment. So, dont ask us,...... its up to you. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
