The first thing I look for is the certified run. With the toughest restrictions applied how much power does it make? If it doesn't do rated with those stipulations I'm not interested. You guys are right. The first thing they need to do is make rated so by reducing the rated you gain credibility. The issue then comes with durability and reliability.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
If I was to buy this amp it would be to run at 1 ohm. Witch it will do over 3k cert in 1 ohm. Bigdwiz didn't have a power supply to push it past the 320 amps that it was pulling. And in the test what was it off buy 50w or something in all cert tests? No even enough to hear to the ear.I dont like the look of the amp or the name. Just sounds cheap to me. But if it last more then few years then I don't see the problem with it.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
It did what at 13.3? 2600? Figure 10 percent per volt. It won't make 3k. It'll be close but not quite. Unless it's user efficient which if it maxed out his 340amp test bench it's not.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Offcourse you wouldn't hear a difference. :)
Still not a difference you would ever hear, even if it only made 2kw instead of 3kw.
Efficiency of roughly 55% at 1 ohm is a little low though,
You may not hear it but I have a thing about not getting g what's advertised
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
My power supply is capable of 320A at 14V continuous. It has surge capacity of over 500A, so that's why I was able to get over 7k on the dynamic tests and only 2600-2880 in the certified runs. I had my clamp meter on the main B+ wire going to the amp and it pegged over 350A during the certified tests. I'm not certain the amp gave up, I think the power supply ran out of current (even though the voltage was still showing 13.3). As I've stated before the certified and uncertified tests are brutal on an amp and unless you play music with extremely long bass notes, it's not representative of the "music" output. For the type of music I listen to, I like to take an average of the certified and dynamic, but that's just me.
See my videos on YouTube http://www.willistonaudio.com  Many tests and demos of OLD and NEW SCHOOL car audio gear!
See cool pics on Instagram @oldschoolstereo
Right and i get that bigd i just look at it differently. Imo it should do rated on every mode. If you start pushing it hard and it falls on its face that's not something i want to have to deal with.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
I am actually a bit impressed. didn't expect it to do that well.
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
  • Who's Online   1 Member, 0 Anonymous, 1501 Guests (See full list)
