2 12 pioneer champ pro box build help
rashawnw
Is possible to have the port on the side but the above would need to be redrawn completely to get equivalent specs.
Specs I found with re calculator (don't know if any good) are 37.5w x 15h x 18d. Box I was working on before was 40 x 20 x 20 way too big. New box comes out to 31.5 hz judging by the calculator. All opinions welcome
RE calculator isn't very accurate.
Is there another calculator I could use. I've heard of Torres but frankly it just confuses me lol. The dimensions i found on re calculator is prob max size I can go. Want it to get in between 30-35 hz
Just built the box and I must say it is a great improvement. Didn't know the pioneers had it in them. Now my dilemma is tuning the amp. Right now its real "boomy" and some songs it sounds like my subs are going to explode. The box should be tuned to around 32 hz and my amp is in the vacinity as well. Any suggestions on where I should tune the amp?
Wish I could help with the tuning, but my same Pioneer was really "boomy" in certain low frequencies... I don't know if its the sub or something else. Maybe your boost is up too high? Other than that, I don't know...
So this box made a big improvement for these subs? I'm still in limbo as to repair my sub and buy another, or just scratch it... Right now, as mentioned above, it's a HUGE paperweight.
2013 Toyota Camry SE
240a MechMan HO Alternator
1/0 Welding Flex Cable Big 3
CT Sounds 4000.1D
Kenwood XR400-4 Mid/High Amp
SoundQubed Q4-120 Mid Amp
Infinity Kappa 6.5 components
Kappa 6x9's for rear deck fill (coming out)
(4) 8" PRV 8MB450's
Set of SoundQubed SuperTweets
(2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure)
(2) SQ HDC3 10's @ 33.5hz (current build, loving them)
Pioneer AVH-X4600BT
100 sq/ft Stinger RoadKill Sound Deadner
120 sq/ft QMat Sound Deadener
(4) Juice Box Black Cherries
Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0
2 Runs of 1/0 Positive front to back
ToolMaker Everywhere
Make sure to not use bass boost on the HU or the amp. As far as gain, see if you can find someone with a dd-1 or an o-scope. Or as a temporary solution look up how to set gains with a multimeter. And make sure to set the subsonic filter to around 28-29ish hz if you can
Brandon
2000 Furd Ranger supercab 4x4
System:
welding wire throughout the truck
USalts 390amp Hairpin
Juicebox in stock location
8 Banks of maxwell supercaps
2 American Bass Vfl 1100.1 wired to .35 each
2 Fi Audio Sp4 18's ( the DD sc 9918's smoked)
Pioneer radio with Soundstream PA mids Powered by a nice sized soundstream 2 channel
It's pronounced (dain-ja rain-ja) :ph34r:
2001 2 door focus
1 DD9918 SC
  • Who's Online   0 Members, 0 Anonymous, 668 Guests (See full list)
