I believe there is no such thing as too much electrical.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Ok as far as three 3100's would I be better off with one D7500 it would take up a little less room and be a little cheaper.
2009 Chevy 2500HD Crew Cab
Current Set up -
Headunit - JVC 6100BT
Mids/Highs - Sundown SA-6.5 CS x2
- 4 Crescendo pwx6.5's
- 2 Crescendo ft1's
Mids/Highs amps - 2 Sundown SAX100.4 V2
Sub amp - NS-1 V2
Alts - 2 Singer 320a 6 Phase
2 XS D4800 under the hood
2 XS D3100's in back
2 Sundown Team 18's walled
Current Set up -
- 2 Crescendo ft1's
Sub amp - NS-1 V2
Current Set up -
- 2 Crescendo ft1's
Sub amp - NS-1 V2
Maybe you should look into a two alternators if you're tight on battery space.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
run a pair of d3100s under your hood, you have 2 stock battery trays under that hood, which should ft a d3100 each, and run your 2 4800s in the rear, or if possible get rid of them for 2 more d3100s
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
If I am correct, 3 d3100's has just under 300aH. That NS-1 is a 6500watt(underrated) amplifier. The alt you are talking about will give you 320A at it's full potential. That means, half of what the amp needs is readily availible, the rest in reserve. That juice in those batts will get sucked out rather quick man.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Yes 3100 is 110ah and 7500 is 140ah
Current Set up -
- 2 Crescendo ft1's
Sub amp - NS-1 V2
I'm overkilling the piss out of my electrical. I'll be running 6 135aH batts on 3.5K for now to later upgrade to 7K down the line. Reserve is a good thing if you plan on running demos.
Cap bank if you want stiff voltage. Look up BlackNasty or SnowDrifter on here and check out their banks. Autocorrect almost changed banks to balls. That would have had quite a different meaning....
Edited by CleanSierra
  • Who's Online   0 Members, 0 Anonymous, 1633 Guests (See full list)
