Kyblack76 Posted March 27, 2014 Report Posted March 27, 2014 Pushes you close to clipping faster. Probably my fault but I've blown a tweeter on my Diamond D1 mids when I had it wired in parallel with my tweeters. Not saying it wasn't my fault but wiring 4 ohm per channel give you more buffer and room for error. Running a lower nominal, makes you clip faster? EDIT- how do you know this? Because you blew something??? Man, im worried now !? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
BoomZoom808 Posted March 27, 2014 Report Posted March 27, 2014 Maybe clipping isn't the correct term but it does put more stress on the driver in my experience. I believe it also lower the damping factor when you run a lower ohm load. 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
BoomZoom808 Posted March 27, 2014 Report Posted March 27, 2014 Pushes you close to clipping faster. Probably my fault but I've blown a tweeter on my Diamond D1 mids when I had it wired in parallel with my tweeters. Not saying it wasn't my fault but wiring 4 ohm per channel give you more buffer and room for error. Running a lower nominal, makes you clip faster? EDIT- how do you know this? Because you blew something??? Man, im worried now !? You have much better than average electrical running lower impedance I am sure is fine in your case. The heat comes in the voltage drop. 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
Kyblack76 Posted March 28, 2014 Report Posted March 28, 2014 Pushes you close to clipping faster. Probably my fault but I've blown a tweeter on my Diamond D1 mids when I had it wired in parallel with my tweeters. Not saying it wasn't my fault but wiring 4 ohm per channel give you more buffer and room for error. Running a lower nominal, makes you clip faster? EDIT- how do you know this? Because you blew something??? Man, im worried now !? You have much better than average electrical running lower impedance I am sure is fine in your case. The heat comes in the voltage drop. Bro.... Im trolling... Im not worried, nor, do i think wiring lower creaps clipping. Clipping is, its own beast, and a nominal load, has ZERO ... zero to do with it. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
BoomZoom808 Posted March 28, 2014 Report Posted March 28, 2014 Thought you might be thanks for the learning 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
Dc 620 Tac Posted March 28, 2014 Author Report Posted March 28, 2014 Think ill just wire the tweets to the head unit an get a 4 channel amp. What class of amp is best for coaxial speakers
BoomZoom808 Posted March 28, 2014 Report Posted March 28, 2014 What is your budget? 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
Dc 620 Tac Posted March 28, 2014 Author Report Posted March 28, 2014 I'm willing to spend 2 to 3 hundred on an amp because I dnt want a real cheap quality/performance. Are do u mean my budget for my whole system?
ChevyBoy95 Posted March 28, 2014 Report Posted March 28, 2014 I'm willing to spend 2 to 3 hundred on an amp because I dnt want a real cheap quality/performance. Are do u mean my budget for my whole system? You are fine running tweeters on channel 1 and 2, and Mids on channel 3 and 4. So a 4 channel is plenty. What is your budget for the 4 channel. Let's take this one step at a time. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
BoomZoom808 Posted March 28, 2014 Report Posted March 28, 2014 This would match your power requirements pretty close and it would match what you already have http://www.sonicelectronix.com/item_60631_Alpine-KTP-445U.html or This one comes with the clean setup technology for setting your gains if you dont want to invest in a DD-1 http://www.sonicelectronix.com/item_67768_Rockford-Fosgate-P400X4.html\\ or http://www.ct-sounds.com/604.html 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
