MrSkippyJ Posted April 15, 2014 Report Posted April 15, 2014 and who doesn't want tar in their car.... F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
BigManAC Posted April 15, 2014 Report Posted April 15, 2014 OP- if you want a cheaper alternative, FatMat has a line called MegaMat that it make with the butyl rubber backing and not the tar on the P&S. It has worked great for me and went on easy just need to be rolled on. I know it's not as thick or as good as the expensive stuff but for the price you can't beat it. I had 50 ft^2 in my trunk and just bought 25ft^2 more for the rest of my car. 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
aculous Posted August 19, 2014 Report Posted August 19, 2014 Companies I have use or sell similar products. RAAMMAT Dynamat SecondSkin SoundQubed or Foam Factory http://www.foambymail.com/VA/polyethylene-foam-roll.html RAAMMAT is the cheapest I have found in bulk but their prices went up. Really it doesn't matter too too much as long as the material is the same. Most companies are selling the same types of products so finish quality may be a lot different and formulation of the material will be of course. Process: Lay up small peices of a butyl/aluminum sound deadner are larger panels to break up the resonnance across the panels and reduce panel flex (you are adding weight mostly), cover in a viso-elastic or whatever its called closed cell foam to break up sound waves and quell rattles. If you want to get fancy you can go to Cascade Audio or better yet SecondSkin and get a spray on sound deadner which I would BET its more like a rubberized material but thats a guess. But the spray on stuff is great for places where its hard to get to and sealing small gaps. Ya know if you are really looking for something cheap closed-cell foam and the foam undercarpet pads are great. You can usually get them from carpet stores for next to nothing and it will kill a couple dB without spending $200+. Just remember that for every dB of white noise you kill, (road noise, wind, engine noise, rattles) thats more of your music that you are going to be able to hear which means you can turn down your stereo a bit and get the same output. Or up your spl score a little bit more I would bet.
