recommendations...not sure where to start
Hey my SMD fam whats goin on? I was wondering if I had any locals to Louisville KY that would be willing to help a member like myself out. Im having some trouble hooking up my headunit and thought maybe a local on here could help me out. I contacted a guy on here before who had the same exact truck with the infinity system in it, but he just kind of overlooked me and i havent heard from him since. Anybody know where I can find the map that has the tools on it? i guess that would be the best place to start. thanks guys
what head unit?
and it is REALLY straight forward.
Just match the harness that came with the radio to the OEM harness. Just match colors, and solder/heat shrink together, clip back into the truck, clip into the headunit, slide it in....
but pictures would help, both harnesses, inside dash where radio is going, etc.
yeah see ive tried that with 2 different HUs ha, ive matched colors across the board and soldered and then heat shrunk them. hook them up and I can get power to the radio and all the functions work on the radio, but I get NO sound what-so-ever. I dont know what else to do. I'm looking at buying a new HU, a decent one, the other 2 were old ones I had laying around. Im looking at the Pioneer DEH-X7500HD, just because I can get it for cheap and it looks like a decent HU. But other than that, the old HUs I used in my other truck and they both worked just fine in the other truck, just for some reason they wont in this one. My truck im digging into now is a 99 dodge ram 1500 and it has the 2 front door speakers, 2 rear door speakers and then 2 tweeters in the a-pillars.
I have a lot of work to do right now but if I catch a minute on my lunch break in an hour I will help you out.
If not, wait until 5pm Eastern time and I will get to it.
Eclipse cd7000
Its all good man, just whenever. I work from 330pm to 1am so I can check it at work here and there when the factory boss isnt there. i appreciate you helpin me out man. things a pain in the ass. ive been researching all over online and cant find anything. i even went over and checked out ramforumz.com and still nothing
My friend bronco had a problem like this, got everything wired up no sound, figured out it had a factory amp.
Just looked it up, if you have the infinity sound system the amps are right at the speakers.
If I'm thinking right the infinity system has its own amps. I don't know if this is possible for you but I can guarantee that it will work and be better than what you had before but run power to the head unit like you did before and then add an amp and use that amp to power new speakers that you replace the old with. A decent 4 channel and just run new wires from that amp to the doors and put in some good speakers. Again I don't know if this is what you want but I recommend it.
Check crutchfield you probably need a special harness if you are going to integrate into the factory system. If you are going to bypass the factory amp. By running speakers off of hu or speakers off a 4 channel amp you need to run new speaker wires to each speaker. Hope this helps
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Can you post or PM me your vin number?
Eclipse cd7000
  • Who's Online   0 Members, 0 Anonymous, 2957 Guests (See full list)
